AJ's Sky UK Channel List **Discussion** Thread
  • cheds
    replied
    yep and also added AMC too
    Leave a comment:
  • mickydibble
    replied
    anybody get sly 80`s movies ?
    Leave a comment:
  • Wes08
    replied
    No joy for me either.
    Leave a comment:
  • Wes08
    replied
    Ok thanks I'll give it a try
    Leave a comment:
  • dpool
    replied
    Originally posted by Wes08
    Hi all, anyone know what's up with LFC TV? I'm just getting a black screen.
    It changed frequencies to 11836.00 H 27500 but i cant get it to work even when i edit it in TP List
    Leave a comment:
  • Wes08
    replied
    Leave a comment:
  • Muckerkev
    replied
    The H2 box nation all working ok
    my Setanta ireland hit are miss
    Setanta HD sound no picture
    premier sports which shows the same as Setanta HD will work but freezes a lot you have to keep going up and down channel to get it to come back on hard to watch football on
    Originally posted by Hadron
    Do you use an F3s/F5s box? There was a known problem with sound but no picture on some channels.
    Do you get the same problem on the following:-
    Baby TV
    GEO UK
    Sony Max
    Boxnation
    Star Gold
    H2
    CI+1
    If so, you may need to update your firmware.
    Leave a comment:
  • digicon
    replied
    surprisingly only Kingofsat list the TP as 11385 Flysat and Lyngsat list it as 11386 who is right who is wrong who cares as long as it works
    Leave a comment:
  • kailani
    replied
    I have a problem with the latest AJay's lists, the TP's on the BT Sports are wrong, they should be 11385MHz because if I load the list as is, they don't work. When I checked KingofSat the TP was different, so I changed it to the above and it worked. There was several other differences too, so I don't quite know whats going on with AJ's lists of late, perhaps AJ can throw some light on it?
    Leave a comment:
  • scotlandw123
    replied
    Hadron,
    thanks for that. My TP List is back.
    If it is only to change a couple of frequency numbers, then I prefer to manually put them in. If I do a full download/update from AJ, I upset all the channels that I have put into a certain order.
    Putting in individual frequencies gives me the least hassle.
    Thanks again big man, cheers.
    Leave a comment:
  • Hadron
    replied
    Originally posted by scotlandw123
    Hi, I have a Skybox F5 and I can't access my TP List to update channel numbers. The TP List is "shaded" compared to other options in that section such as "Installation Antenna", which are lit up in bright letters. I need to access my TP List to change the frequency numbers. This has never happened before and would be very grateful for some helpful advice. Cheers.
    Some options are greyed out if no satellite is ticked in the satellite list.
    Go to menu > installation > satellite list. Scroll down to SKY UK 28A. If it hasn't got a green tick next to it, then press OK to do so. Press EXIT on remote. TP list should now be available.
    btw...why do you need to change frequency numbers. Isn't AJ's latest list working for you?
    Leave a comment:
  • scotlandw123
    replied
    Leave a comment:
  • Hadron
    replied
    Originally posted by Muckerkev
    My Setanta HD not working sound no picture
    Baby TV
    GEO UK
    Sony Max
    Boxnation
    Star Gold
    H2
    CI+1
    Leave a comment:
  • Muckerkev
    replied
    Leave a comment:
  • DeejayAJ
    replied
    New update here - http://www.digital-kaos.co.uk/forums...=1#post2587881
    Leave a comment:
