AJ's Sky UK Channel List **Discussion** Thread
  • snowie14
    replied
    Originally posted by DeejayAJ
    none of the channels are working all scrambled, was working perfect yesterday, is it due to server down, all boxs i installed have problem
    Leave a comment:
  • DeejayAJ
    replied
    Small update here - http://www.digital-kaos.co.uk/forums...=1#post2609580
    Leave a comment:
  • Hadron
    replied
    Originally posted by badboynads
    Some of the channels are missing like
    Islam Channel
    Sony Max
    Both channels available on AJ's latest list here.
    Islam channel on 382 in the "all" channel list (ch 38 in the International fav).
    Sony Max on 357 in the "all" channel list (ch 13 in the International fav).
    Leave a comment:
  • badboynads
    replied
    Islam Channel
    Sony Max
    Leave a comment:
  • snowie14
    replied
    My v8s box is working perfect but the the irish channels rte1 rte2 tv3 and sometimes setanta scramble and then work fine and then might freeze . All the rest of the channels perfect , would anyone no why this is just with these channels
    Leave a comment:
  • P&D
    replied
    Originally posted by paulheb
    Hi AJ
    I have just downloaded your updated channel list dated 12-09-2015 and put onto my Openbox but I am getting scambled across all channels?
    Are you getting the FTA channels BBC ITV ?
    The channel list has nothing to do with decoding the channel.......
    where they ok before you loaded the new channel list ??
    Leave a comment:
  • paulheb
    replied
    Hi AJ
    Leave a comment:
  • Hadron
    replied
    Originally posted by 9821
    Hi Hadron - Its screwed into LNB port....any other settings I can check..Internet works fine... if i change the source to TV (Free sat works fine too)
    The only other setting I can think of that will give no signal is if the LNB power is set to OFF in the installation menu.
    Do you have separate feeds to the LNB (you're not using a splitter to feed the F5s & Freesat box).
    Leave a comment:
  • 9821
    replied
    Leave a comment:
  • Hadron
    replied
    Hi all my channels are showing "No Signal" I have recently moved into a house and got the dish installed which worked fine on Free sat however when I connect my sky box F5s i dont get signal at all ...[ATTACH=CONFIG]332780[/ATTACH]
    I know it might sound like an obvious question, but have you got the cable from the LNB screwed into the LOOP connector by mistake?
    It wouldn't be the first time that someone has done that.
    Leave a comment:
  • 9821
    replied
    Hi all my channels are showing "No Signal" I have recently moved into a house and got the dish installed which worked fine on Free sat however when I connect my sky box F5s i dont get signal at all ...IMG_0569.JPG
    Leave a comment:
  • Wes08
    replied
    Originally posted by P&D
    Hi is this what your looking for dated 15-Sept
    I not used it because i don't have that box
    I've just PM'd you the link because i don't know if i can post in the open forum
    Thanks, I think I bricked my box but I'll try it if I get it up and running again.
    Leave a comment:
  • P&D
    replied
    Originally posted by Wes08
    Love this channel list AJ works perfect on my v8s, any chance of it for my amiko mini combo, its .abs file, would really appreciate it as there is nothing else available.
    Leave a comment:
  • joe516
    replied
    Is there any way of converting the file to work on the Amiko mini combo?
    sorry no m8
    Leave a comment:
  • Wes08
    replied
    Originally posted by joe516
    no m8 not 4 the amiko mini combo
    Leave a comment:
