AJ's Sky UK Channel List **Discussion** Thread
  • aaizoo
    replied
    Originally posted by Hadron
    Are you saying that every single channel can no longer be viewed (including FTA)?
    If so, then it's got nothing to do with the channel list.
    What message do you get on screen?
    Yes, i am getting only free channels every single channel no longer working
    On screen it shows SCRAMBLED
    Leave a comment:
  • kman999
    replied
    Great list as always and quickly updated. Just wondering if anyone has noticed Sly 3d is missing under entertainment
    Leave a comment:
  • QPRsteve
    replied
    used this channel list yesterday now all channels are scrambled could someone please advise what i need to do?
    Leave a comment:
  • Hadron
    replied
    Originally posted by aaizoo
    Hello AJ i have a skybox f5s about 1 week ago i downloaded that tp file for channels and succesfully got all my channels but now all channels gone...
    Leave a comment:
  • aaizoo
    replied
    Originally posted by andy91
    Have you rebooted box?
    Andy
    Yes rebooted it but nothing happened updated the software also for f5s but nothing happened wat else i can do no idea
    am i doing something wrong
    Leave a comment:
  • andy91
    replied
    Andy
    Leave a comment:
  • aaizoo
    replied
    Hello AJ i have a skybox f5s about 1 week ago i downloaded that tp file for channels and succesfully got all my channels but now all channels gone, i followed the same procedure but nothing happened, I have followed this info of yours "
    FAQ
    How do I put this list on to my box?
    Firstly, before any upgrade you should always backup! Once you've done that;
    1. [*=1]Unzip AJ's List XX-XX-XX.zip with a program such as winrar & place the TP_PROG.DBS file onto the root of your USB drive.
      [*=1]In the Openbox menu delete your current channel list by going to the "Edit Channel" tab & selecting "Delete All".
      [*=1]Staying in the menu navigate to the "Tools" tab then "Upgrade by USB", change the upgrade mode from "Image File" to "Misc Files" then "Select & Upgrade" & select "TP_PROG.DBS" then press yellow, if all done correctly it should begin to upgrade.
      [*=1]Once the upgrade has completed restart your box & voil?!
    How do I backup?
    Make sure your USB is plugged in then navigate to Menu > Tools > Dump by USB > Change Dump Mode to "Misc File" > Click on "Select and Dump" > Select "TP_PROG.dbs" so it has a tick next to it then press yellow to "Dump onto USB", this will backup your channel list. To backup your "gift" just select the "CCcam.cfg" file instead of "TP_PROG.dbs". To backup your whole image "Dump to USB" before changing the dump mode. The required backup should now be on your usb stick, make sure to move it to your pc or be careful not to delete it.
    but without success, i am a total newbie so be easy on me ; p am i missing something ? Because your thread says that it will work on skybox f5s.
    Oh and i tried directly downloading from your webpage AJsat.co.uk but not worked help plz
    or any one else plz
    Many Thanks
    Leave a comment:
  • DeejayAJ
    replied
    New update here.
    Leave a comment:
  • P&D
    replied
    Originally posted by epeppard
    Hi, i'm looking for a channel list for skybox F6 that includes irish chanels, and as many other channels/ satillites as possible
    AJ's Sky UK **Channel List Only Thread** for X5/F6 - Updated Regularly
    Leave a comment:
  • epeppard
    replied
    Leave a comment:
  • theroadend
    replied
    HI can any one help need to update firmware on skyboxf5s thanks
    Leave a comment:
  • lupin123
    replied
    Thanks works wonders much appreciated. my sky sport 5 will not work or struggles but fine on vu ultimo and 500 s and segestions much appreciated
    Leave a comment:
  • DeejayAJ
    replied
    New update here.
    Leave a comment:
  • mark5211
    replied
    Originally posted by R0BINH00D
    Mark..... I had this problem but its all sorted thanks to the "no signal fix" that I was told about and got some for my boxes on ebay ever since never had any "no signal" messages just search -----> SKYBOX F3 F4 F5 AND F3S - OPENBOX S9 S10 S11 NO SIGNAL FIX
    hope this helps like it did me
    Ill take a look at those thanks, its all working again today so it seems pretty intermittent.
    Leave a comment:
  • R0BINH00D
    replied
    Leave a comment:
