Ignor above, flashing Ajs channel list 1st and adding additonal sats and ONLY scanning the Additional Sats for there own channel list worked.
I was doing 2 things wrong, that you~~~~/youtube firmware must have its own uk channel list/fav list so factory setting the box re-enters the default list, but you MUST delete the channel list only and then use Ajs list and scan for your Sats/new Sat channel list.
Also dont rescan 28e after installing AJs list cos that messes up the channel list !
I wish these firmwares did not come with any channel list, that way one could cleanly install there own channel list or better yet have Ajs list installed along with the firmware and while at it add the Other Sat list to the list making it easy to scan.
If your only using 28e then Ajs list is gold dust
