AJ's Sky UK Channel List **Discussion** Thread
Mate, you have to rename each one yourself.
Look at the category list of page one, and then rename each favorite 1, favorite 2 accordingly on yours.
Once done, future updates with AJ's list will not need renaming.
CheersComment
Hi MG,
when i completed these steps all the original fav were still their and did not need to be renamed, do you think i need to do a firmware update?
BComment
You might wanna read the FAQ in the second post. Channel list upgrades don't effect the favourites names, they will stay the same through as many updates as you like until you manually change them in the menu with the remote.
If you can't manage without favourites you'll need to upgrade to a newer firmware, make sure to make a backup first especially if you have important files like CCcam.CFG for server info.
There's an FAQ in the 2nd post.
Channel lists don't change the names of you favourites, you have to change them yourself in the menu with the remote.
I think they're similar to the BBC/CBBC setup where it's one channel through the day & another at night.Last edited by DeejayAJ; 8 January, 2013, 03:48.Comment
Help lost sound will the new update solve this problem.
Laura XxxNever eat yellow snow
Don't forget to thank me
TOGZ
how do i edit the fav channel list as it is just comiing up fav channel 1.2.3.4.5.6.7.8.9.10.11.12.13.14.15.16.17.18.19.20 etc i want to name these.
laura
TOGZ
Hi I downloaded the file but get the message:
the archive is unknown format or damaged
any ideas how to resolve this please?
thanksComment
you have to download this as a win zip file make a folder up on your desk top ie tv guide when you download this save it in there and then when you extract it save it again in another folder then open up that folder then right click then send to usb stick then you know the rest. hope that helps.
TOGZ
HAve tried that it still does not workyou have to download this as a win zip file make a folder up on your desk top ie tv guide when you download this save it in there and then when you extract it save it again in another folder then open up that folder then right click then send to usb stick then you know the rest. hope that helps.
Laura Xxx
you then put it in the skybox or what ever you have then upgrade by usb then add then update then go to the satellite list then the box should turn off and then you should have it on your box. you cant view them on the computer only on your box.
TOGZ
Nope still not working same error and I have downloaded other zip files and they work great.
Deffo an error somehwere, I'm using win 7 64 bit
