AJ's Sky UK Channel List **Discussion** Thread
  • colly109
    • Sep 2013
    • 10
    #1891
    Originally posted by DW190
    The file has been extracted.
    I am doing something wrong it would seem I put it into the box and All I got was cccam.cfg not found message
    • DW190
      • May 2012
      • 1263
      #1892
      Thats because the channel data is a file called TP_PROG.dbs.
      Menu
      Tools
      Upgrade by USB
      Change from Image to Misc
      Select and Upgrade
      Press OK to place a tick at the side of TP_PROG.dbs
      Press yellow button.
      When finished exit exit exit and box shoud reboot its self. If it doesn't reboot it.
      • MarmiteX1
        • Aug 2013
        • 41
        #1893
        Sony Tv Asia, and Zee news are coming up as Invalid program. This needs fixing please.
        • tbyrd16
          • Jul 2013
          • 14
          #1894
          Just a big thanks To AJ for the fantastic lists we all get. Usually always fine for me. Although the last 2 lists Ive lost Atlantic+1 which was ok before and works on satv5 list too. Want to keep AJ list because I prefer the format. Any idea why I cant get just this one or how can I rescan to get one that works. Thanks in advance.
          • amzi160586
            • Sep 2013
            #1895
            Thanks Aj for the updated list, don't think I'd updated mine since like Sept 2012 (LOL)...think this may have been mentioned on here before, but I cannot find any answers, but amongst the Asian Channels I've noticed that Sony TV Asia and Zee News are scrambled...can anyone confirm this is a wide spread issue and if there's a way to get these back up and running...rest all looks perfectoooo, so thanks once again!
            • colly109
              • Sep 2013
              • 10
              #1896
              Menu
              Tools
              Upgrade by USB
              Select and Upgrade
              I have put the tp_prog.dbs file onto the usb,and as mentioned before seemed a white document when extracted doesnt look right
              The 5 options i have when update file by usb are cccam.cfg cccam.prio constant.cw softcam.key smartcard.conf
              • colly109
                • Sep 2013
                • 10
                #1897
                Cheers i was in wrong section though all i am getting on screen is a blue i no signal lead from dish is fine works on another box
                • Hadron
                  • Nov 2012
                  • 2102
                  #1898
                  You only need to go back a few posts to see what has happened to Sony TV asia, & how to fix it.
                  As for Zee News. What does your EPG say? Mine says "programmes start at 1.am" It's been showing this for weeks. Does it just broadcast overnight now?
                  • DW190
                    • May 2012
                    • 1263
                    #1899
                    Have a look in the satellite list and see if there is a tick at the side of 28.2.
                    • shadowless
                      • Apr 2013
                      On the latest M3 firmware 28/03/2013 and my list of favorite channels are showing as FAV 1 FAV 2 and so on rather then Entertainment and so on. Is there a fix for this?
                      • sattv5
                        • May 2013
                        • 376
                        #1901
                        The way to get The favourites under the correct headings is to load the default Database:
                        On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Dont press anything other than blue)
                        The screen will flash black for a second and you will be back at the menu. If you check your favourites now they should all be in the correct order
                        • zevrep
                          • Jun 2011
                          • 17
                          #1902
                          hi mate could you do one without the adult please? im in NW so this would be great
                          • markbirch1977
                            • Feb 2011
                            • 106
                            #1903
                            does any body no where discovery shed has gone thanks
                            • singh1234
                              • Aug 2009
                              • 156
                              #1904
                              have st downloaded ajs 24/9/13 list, does not include e entertainment channel and sony tv Asian and ptc Punjabi does not work,any help?
                              • amzi160586
                                • Sep 2013
                                #1905
                                Hi Hadro,
                                Okay So I've updated as per your previous post on how to fix Sony TV Asia...I'm still getting scrambled on the 12051/27500/V frequency...any ideas? Is it working for you?
                                Thanks,
