BEST Sky UK Channel List 100% same channel numbers
  • rogerdygas
    • Dec 2011
    • 18
    As title this is a UK Sky Channel List for all Openbox's. This list has the exact same channel numbers as SKY UK eg 101 BBC Once, 106 Sky one, 520 Discovery etc. Asian channels aren't to order as I never watch them.
    Suitable for openbox and anybody S9 S10 S11 and S12
    How to add list
    ***65279;Below is from Shady's sticky.
    1: Copy contents (TP_PROG.DBS) of downloaded file to USB drive formated to fat32
    2: Press Menu on remote, and highlight
    "TOOLS"
    3: Select'Upgrade by USB'
    4: On new window, use arrow keys to
    change top line to 'MISC FILES'
    5: Move down to 'SELECT AND UPGRADE' |
    6: A new window opens, select
    TP_PROG.dbs' press green button to place
    a tick by it and then press yellow button
    to upgrade
    7: If the box asks anything just press yes.
    Any problem please let me know so I can fix. If you like this then please hit thanks.
  • ricki1
    • Jun 2012
    how do i instal this? ii have openbox
    • wonders2010
      • Aug 2011
      • 13
      I installed your list and found all the western channels all in order but the asian channel order was incorrect, alongside certain channels missing like ARY NEWS and ARY Enterainment. SKy 2 shows as scrambled for some reason on your list.
      • rogerdygas
        • Dec 2011
        • 18
        I didn't even bother with the Asian channels as I dint watch them. I will add the missing channels and repost I'll also sort sky 2 out.
        My aim is to have the best sky list freely available to everyone so any suggestions are appreciated!
        • casper1690
          • Feb 2011
          • 213
          hi i spent hours tryn to sort my chan list out will this work on s9? how do u install?
          • rogerdygas
            • Dec 2011
            • 18
            It will work on an s9 as s9 10 and 11 all accept the same channel list. For instructions on installing please find the post above, it has a link showing you how to install.
            • total newby
              • Feb 2011
              • 183
              Please hit thanks if you like
              Suitable for openbox and anybody S9 S10 and S11.
              For a guide on adding this to your box see the sticky detailing setup of openbox.
              will this work on a openbox/skybox s12 original?? thanks bought from ebay
              • rogerdygas
                • Dec 2011
                • 18
                Yes it should work.on an S12
                • mohdq
                  • Jun 2012
                  • 4
                  Zee Cafe
                  A small observation, Zee Cafe is on 846 on sky not 849.
                  • SentineI
                    • Jun 2012
                    • 11
                    Also, Desh TV on 834 has been replaced with Channel Nine
                    • jimbobfeelie
                      • Jun 2012
                      Help!
                      I uploaded this to my s11 as per instructions now box is stuck in a boot loop, with an stpt message on the box
                      • jimbobfeelie
                        • Jun 2012
                        Well its a skybox s11 is that why? or should it be compatible
                        • SentineI
                          • Jun 2012
                          • 11
                          It should definitely be compatible.
                          My (first ever) Openbox came through the post today and it is an S11.
                          I'm currently using this channel list. I had to reboot to make the changed apply though.
                          Did you buy your box off eBay?
                          • roadie
                            • 130
                            will this work with openbox x3?
                            • jimbobfeelie
                              • Jun 2012
                              No friend of mine came and set it up this morning for me, thought I'd prefer this list as used to sky channel numbers, seemed to install fine, turned box off to reboot and been stuck in a boot loop ever since, looks like I'm off to buy a null cable tomorrow
