I bought an Openbox S9 yesterday and have lots of problems with it.
I am an expat in Indonesia and use Indovision for my tv.
So I do have a subscription but wanted my own box to see their HD channels which are free but need a HD Box.
I set the box up and the channels are all there but scrambled.
As soon as I insert the card it crashes and reboots, then there are only two dashes on the display.
If inside and switch off and on it's the same.
firmware is old, HDS2-1010-26: 1647CMT, also I think I have a genuine box, but I can not read the CCID cause it crashes when inserting the card.
It only shows ff00 but I think that may change if card inside.
I want to update the firmware, might that solve the problem.
Problem is though there is no USB upgrade in Menu.
Is it possible to upgrade over LAN?
Otherwise I need to update over serial I think, then have to buy a cable.
Another problem, I have a powerbook g4 which can not run windows and don't have access to a pc.
Possible on a mac.
Is there a nice guide how to do this.
One more thing, if you are in 1080i mode is only the tv channels 1080i and not the menu, my menu is just part of screen, is that normal?
Lots of questions, greatly appreciate some help.
Cheers Perry
Edit to update:
Resolution problem solved, had to switch RGB to YUV and then I could set the right resolution, then set something (forgot)more to Auto.
Even a small Raspberry Pi does this much better, why not here?
Possible on a mac.
Cheers Perry
Edit to update:
