Skybox F3 and scrambled channel
  • camane007
    • 23
    Hi everybody
    I got an Skybox F3 as works well....but sometimes the channel changes to " scrambled channel " and after 10 sec thats ok again........i've changed the firmware to the last one (2012.08.08) but stll have the problem. Thanks in advance for all help.
  • nibblitz
    • 1300
    Either the network connection is a bit iffy (best to use wired rather than wifi) or more than likely the server you connect to is poor.
    • camane007
      • 23
      Thanks Nibblitz for your quick replay, i use wired conection and i even use the same server for an original DM800 as haven't has this problem.
      cumps
      Camane00755
      • jd1888
        • Aug 2012
        • 5
        hi,
        on a similar note i get a 'freeze' or pixellation on the screen now and again where it lags for a second and then it goes back to normal. would this be router related too?
        • wroenaldinho
          • Aug 2012
          • 56
          this also happens to me, when i trun box off and back on everything is then fine, got mine connected via net plugs.
          other than this everything is fine, its just now and again.
          • camane007
            • 23
            Hi, tell me please wich firmware do you use on your Skybox F3 ?
            • wroenaldinho
              • Aug 2012
              • 56
              one that came with the box
              very rarely does it though
              • jd1888
                • Aug 2012
                • 5
                would the strength of the satelite signa affect this? Im getting around 75%
                • jd1888
                  • Aug 2012
                  • 5
                  whats the general consensus of homeplugs vs wifi dongle for stability?
                  • impassivepig
                    • Sep 2012
                    hi i keep having the same problem anyone got a fix? could it be the lnb
                    • camane007
                      • 23
                      Problem with Skybox F3
                      I still have the same problem too, i changed the firmware to the last one ( 08-08-2012) and tried also with another c-lines but the problem remains with " scrambled channel " and after 10 sec thats ok again ( my DM800 works well with the same c-lines ).
                      • digger99
                        • Dec 2011
                        • 99
                        Have you tried the "scooby snack" firmware, I was having similar problems and was told about this firmware and it seems to have solved this issue.
                        • camane007
                          • 23
                          Hi again , where can we dowload the new firw from them ? " TDB_F3.Scooby_Snack.abs " ?
                          • marty47
                            • Jun 2012
                            • 31
                            the simple answer to all your glitching queries is the box isn't getting the key information quick enough this can be caused by many factors isp problems, weather conditions equipment, cabling, dish condition etc how you connect wifi ethernet, your server., firmware. one all or a combination of these can cause problems as best you can eliminate them one at a time to get fix thats right for you remember it might be a server issue for you and an isp for someone else and so on
                            • joe516
                              • 1000
                              75% is ok m8
