Hi there found the problem I think I posted before that I could not view some channels ie sky sportshd 3 espnhd found that if I select the channel there is no sattelite signal but if I go into menu then lmb power settings turn it off then back to on straight away the channel works but if I change channel and go back it wont work have to turn the lmb power on and off again any ideas read about a fix for it help its not transponder as first thought I think
open box lmb power problem
hi i have tried the box at my mums house and sky sports 3 hd and espnhs both diplay so its either the lnb at my end or i might get one of those open box fix kits they sell for around a tenner changes voltage or something i can display the channels if i turn the lnb power setting off then back on it displays so must be voltage like i said thanksComment
I had this problem m8 read lots of posts about replacing thermistors and lnb I eventually bought a zinwell sky quad low power lnb and all my problems disappeared. Hope this helps.Comment
I have sorted it I swapped the lnb from my mums house its an old grundig one works on but some channels have low signal strength about 50% some are around 90% any ideas the main one is sky sports hd 1 its about 38% might buy a satellites amplifier would this help thanks allComment
