Stb memory error!
  • wroenaldinho
    • Aug 2012
    • 56
    Stb memory error!
    Stb memory error..all i ever get on skybox f3. Tried 2 null modem cables both same results using dedicated loader. Can hear a slight ticking noise on board when i turn switch on on the box..opened it all up and it looks fine,just cant get it to do anything.
    Came home one night and box was off.
  • mast
    • Nov 2010
    • 1027
    I would check the power supply. Check for correct voltages with meter.
    Regards
    • wroenaldinho
      • Aug 2012
      • 56
      Ive ordered a new psu at the moment but will take 3 weeks to arrive.
      What voltages am i looking for?
      • slugworth
        • Nov 2011
        • 1064
        don't have one but sometimes the voltages are silk screened on the board where the ps connector is.
        Usually 5v,3.3v,12v,24v
        • wroenaldinho
          • Aug 2012
          • 56
          Thanks for your reply...if it is the psu which i suspect it is, if i replace psu board with a new one,should this solve it.
          • mast
            • Nov 2010
            • 1027
            I would think so, let us know how you get on.
            Regards
