Openbox x3 Dead...
  • geordiemax
    • Nov 2012
    • 4
    Openbox x3 Dead...
    Hi guys I wonder if you can help me my open box x3 arrived yesterday installed fine scanned 2 satellites was all working perfect went to scan a third satellite it got to 100% then froze, I turned the power off then back on again now all I get on my open box x3 display is a dull number 8. can you guys help me?
  • DW190
    • May 2012
    • 1263
    Here you go. Try the attached Upgrade programme.
    • geordiemax
      • Nov 2012
      • 4
      Do I just connect it all and run EromUpgrade i keep reading about a batch file but I don't know what that does or how to use it?
      • DW190
        • May 2012
        • 1263
        Just connect it up and enter the abs file that in the file uploaded. Tick include bootloader.
        Box powered off
        Start the loader
        switch box on
        May need a few attempts.
        If your using a laptop with a USB to Serial adaptor you need to select the correct port.
        • slugworth
          • Nov 2011
          • 1064
          that file is just the loader
          you will still need the proper firmware to load.
          I don't think it works with usb adapters.
          The batch file just made the proper eromclient.abs file
          for a version that had support for different models.
          That zip already has the proper file.
          • geordiemax
            • Nov 2012
            • 4
            OK thanks, I have ordered some parts will let you know how i get on
            • nestlik
              • Mar 2013
              hi have u solve the problem??? got same issue, looking 4 some ideas
