Star plus hd not working
  • hkhan
    • 74
    Hi guys my star plus hd has stopped working have rescanned and no luck has the frequency changed has anyone got the channel updated on there channel list thanks
  • mast
    • Nov 2010
    • 1027
    Just uploading updated channel list now.
    Regards
    • Mysteriousguy
      • Aug 2012
      • 56
      Same problem here mate.
      I am informed the frequency has changed.
      • mast
        • Nov 2010
        • 1027
        2 days ago when I did the list it was fine, has it changed since.
        Can you confirm and let me know as I dont really have an openbox so I can sort it.
        Regards
        • lincsat
          • 1228
          The new frequency started a couple of weeks ago - 10935 V 23000 8/9, sharing a Transponder with a couple of ITV 1 HD's - basically it's where Alibi HD used to be.
          • zee24
            • 3342
            yes the frequency has changed on my blade as well had to manually scan the channel
            • mast
              • Nov 2010
              • 1027
              So the updated list from 2 days ago should be fine then as it was working when I dumped it.
              If someone confirms in the stickie thread would be great.
              Regards
              • hkhan
                • 74
                hi guys will put the newest channel list from mast and see how i get on, also does anybody on here now when you scan an openbox how to scan for a specific channel if your missing it... thanks
                • mast
                  • Nov 2010
                  • 1027
                  Do a single transponder scan but input the new frequency and symbol rate save and then scan.
                  Any channels on that frequency will be added to your all sat list.
                  Regards
                  • hkhan
                    • 74
                    hi the current channel list from mast is working and star plus hd is fine, only channels which are down are:
                    NDTV 11488
                    mta-muslim tv
                    star news
                    rishtey
                    by the look of things the frequency has also changed for these channels
                    • mast
                      • Nov 2010
                      • 1027
                      NDTV 11488
                      mta-muslim tv
                      star news
                      rishtey
                      Will try and sort this tomorrow m8, although as I said in pm the frequencies match up with me dreambox.
                      Edit: Been told by another member that Star News has been replaced by Star Jalsa which is in the new list.
                      Regards
                      • hkhan
                        • 74
                        okay well try and see if you have any luck with NDTV 11488
                        MTA MUSLIM TV & RISHTEY. also is it just me or is primetime just closed or not working?
                        • rborhara
                          • Dec 2012
                          • 32
                          Star Plus HD still freezing for me even with latest channel list , on both of my openboxes.
                          Can it be a cline server thing?
                          • Mysteriousguy
                            • Aug 2012
                            • 56
                            I was having the same problem on Tuesday and Wednesday.
                            Yesterday and today the channel has worked perfectly on HD.
                            Try the new channel's list update on AJ's page by another member who has added the SD version of Star Plus. If that works fine, most likely it will be the c-line server.
                            • Mysteriousguy
                              • Aug 2012
                              • 56
                              I know my supplier was updating his end, hence the channel was glitching a lot. But past two days have been good, most likely the c-line.
