Anyone recommend a usb wifi for the openbox x3 just bought and want to have it wireless as the router is a bit from the from the openbox and don,t want ethernet cable lying everywhere. Many thanks for any replys
Wifi usb
make sure ur dhcp is off and ur password is correct including low and high case letters. also ive found that some x3's take a good few tries before they finally connectComment
Remove WEP/WPA password at router page and you wont have to.
Or you can do that and......
On computer, setup new connection manually. Type in wifi name and WEP/WPA pwd and save.
Set this new wifi connection to connect even if not broadcasting or offline mode. Set wifi not to broadcast in router page.Comment
