SKYBOX F5
This topic is closed.
lads just a quick question ref youtube in the skybox f5 .
i get the you tube say to do a search for the most popular youtube clips on the net . it comes back with the search result showing the various clips it hads found . but when you go to play them it won't play .
is this a common software issue or is there other settings in the box that have to be reset a different way .
tks in advanceComment
This is a software issue which has been fixed in the latest released version for the F5S but as of yet there has not been a new version released for the F5.lads just a quick question ref youtube in the skybox f5 .
When I tried you p0rn yesterday (& on previous days), I got the loading dots that counted up to 100, but then went back to zero & counted up again. It kept doing this over & over again.
When I tried this morning, the clips loaded but they are glitchy & keep buffering.
You tube clips working fine.Comment
Hey folks, I'm a complete noob when it comes to this sort of thing so I was hoping I could be given some guidance. I have a Skybox F5 but haven't updated the firmware in a while (a friend of a friend set it up). I was just wondering if I can update the firmware and not have to enter CCcam info?Comment
When you update you flash the firmware to the box replacing the original firmware within the box with a new or different firmware you could backup your settings to a flash drive put the new firmware on the same drive update the firmware the update from usb then same update from usb softcam cccam etcComment
A member of nearly 6 years and has still not read the Forum Rules: http://www.digital-kaos.co.uk/forums...rules-2/#post2
you cannot miss them they are highlighted in RED
- Discussions about cardsharing are not allowed, including, but not limited to, CCcam, Oscam, MGcamd, Gbox, Mbox, etc....
- Discussions about servers,clines etc will be edited or removed.
- no asking for lines.
