nice 1 i'll give that a go tmoz , had enough for today , thanks for your time mate i'll be on here tmoz if i get stuck
skybox f4(new openbox)setting up motor please help
Your Lat; is 53.44 North - Your Log' is 2.67 West
(you should enter your Lognitude as 002.67W on your box, not 000.27, as that would be 0.27 east, you're 2.67 west ...)
East are positive Longitude, West are Negative LongitudeLast edited by nibblitz; 23 December, 2012, 22:35.Comment
000.27 is what is is in my box, but then again i have the option to change from east to west and north and south..
when i put it in as 2.odd the dish ****ed off in wrong direction
Use usals and the dish will go where it's told to go by the box, if it is slightly off then swap to disq then you can stab it left or right a budgies peckerIf it isn't broke, don't try fixin it..!!!
about 10 mile away from where this lads trying to set up
longitude in box 000.243 west
latitude in box 053.587 north
use usals for this sat = yes
google sat finder/dish pointer
Latitude: 53.5843?
Longitude: -2.4319?Last edited by darcu5; 24 December, 2012, 11:29.If it isn't broke, don't try fixin it..!!!
when i did it the other way dish went opposite way, when i entered it like this it works fine, and has done for last 2 years so i'll leave it be
Like i said in earlier post i didnt even enter lat and long in the openbox, just set my dish to 1w and let usals do the rest,If it isn't broke, don't try fixin it..!!!
I came across a similar problem (with the dish moving in the opposite direction to what it should) on a Ross HD box.when i did it the other way dish went opposite way, when i entered it like this it works fine, and has done for last 2 years so i'll leave it be
It was a b**ls up in the software, and you had to enter your latitude as 'south', even though it should have been 'north'!.
So you've got your box and dish thinking you're at 0 degrees longitude when thats not actually where you are, it'll still work, but Im sure USALS will slightly be off with satellites across the arc, hence why you've had to, as you said, use diseqc to move it manually by a "budgies pecker"
But ah well, if its working for you how you have it then ok... But its only proper that we have informed the OP how to correctly input the settings.Comment
got me baffled now, i followed a tutorial on here when i was setting dish up, i entered details as you and nibblitz say it should of been but got nowhere, entered it as i have it set now and it worked fine, picks up from 28.2e to 30w and only have the 80cm dish up now instead of the 1.1m..
i just left it as it was cause it was working fine, i'm gunna have a go again at it now, but will wait till the weather picks up, i'm to old to be playing about in rain now
cheers for pointing it out to me.If it isn't broke, don't try fixin it..!!!
hiya again guys this is getting werid, did the usals picked up 5e as 7e 13 e fine but 16,19 and 23.5 all messed up 16e be comes 19e in parts and the rest it can't find. 28.2 no probs. if itry to scan on disque from 1w to find 5e i can't get it. is there a list of transponders i should scan on each sat. it's so frustratingComment
