Are you sure the USB port is working, does it see a memory stick ok? Does your hard disk have just one partition which is either fat32 or ntfs? If its a USB powered portable drive then it might not be getting enough power.
yes it is USB powered, my laptop picks it up fine and the USB stick is picked up fine by the box aswell... what i have is a Laptop HDD put inside a enclosure. :S
