Skybox f3 help
  • Flipside
    • Jan 2013
    Skybox f3 help
    Hi am new to all this, ive a sly card from my dad multiroom box, is there a way I could make it work with this skybox f3,
    anyhelp would be very welcome
  • mdt
    • 3034
    your dads multi-room box will be connected to a phone line and if its misses its call back they will charge him full wack for 2 full subs so be carefull,regards mdt
    • Flipside
      • Jan 2013
      oh right they check the viewing card aswell with the call back?
      • darcu5
        • Jun 2011
        • 944
        yes you can, you need to pair the box with the card.. use scientific calculate or a box key generator (not an online one) enter the 15 or 17 digit number on the bottom of the box and change it to hex. you then end up with the 8 digit code you need to enter into your f3 under card set up. If there is only 7 digits once you have converted to hex then add a 0 to the front.
        • Flipside
          • Jan 2013
          Thank you, ive done all this & got it working, so when sly call back my dad box back will it be ok, or will they know the viewing card missing?
          • darcu5
            • Jun 2011
            • 944
            if they did they would contact him asking why it isnt plugged in to phone socket, just tell them no idea and will get son look at it later (just play dumb), gives you time to tek it back round and plug it in then phone them up. i know 2 people who have had multi room fitted in last 12 month and the fitter didnt even bother running a phone line upstairs..
