Hello,
I have 2 Openbox S10 boxes coming off individual feeds off a quad LNB dish
I have 1 on a direct ethernet feed from my wireless router and 1 fed via a WiFi Bridge fed from the same router.
I am only able to watch via the boxes individually, if i have both boxes switched on I am only able to watch the one fed by the ethernet cable, the other box has scrambled channels.
I have checked the settings and find the IP address are the same on each box, the baffling thing is I also have 2 cable boxes which are internet fed in exactly the same way and they have different IP addresses and they work fine.
I am presuming it is the IP address element that is the issue.
Any ideas or suggestions would be gratefully received.
Thanks in advance
Thanks in advance
