Skybox f3 no signal or box dead??
  • Zizzo
    • Dec 2012
    • 56
    Three days ago I saw a lot of freeze on my box so I thought maybe the problem is just normal or because of the snow, so yesterday when I switched on the tv seems to get no signal in all channel, I decided to delete all satellite and trying to rescan everything again even AJ SKY LIST upgrade new one as well, so after that I can't get anything even single tv when I search I found nothing and my dish outside is working fine because am using motorised dish so I have got no idea now what should I do or my box is completely dead?? Any advice please please, also I have attached few pictures....also on the Network Local Setting DHCP suppose to be off or on??
  • nibblitz
    • 1300
    Are you sure theres nothing wrong with your dish? Does it still actually move, have you checked the cable termination into the motor, and also the terminations from motor to LNB, maybe theres been some water ingress..
    • Zizzo
      • Dec 2012
      • 56
      Dish is working fine without any problem at all, also now when I install that AJ channel list am getting 76 redio only and some of them they are working fine and I can't get even single tv channel only redio so I have got no idea, also my dish is moving without any problem....
      • nibblitz
        • 1300
        How do you know your dish is working fine?
        • Zizzo
          • Dec 2012
          • 56
          That is a good questions, actual when I add the AJ channel list and try to rescan I can see the dish is moving outside and is going different direction, then is showing high quality after that stopped, yesterday I was getting hotbird but now even hotbird is not working as well, so you think the problem might be firmware or dish??why am getting only redio instead of tv??
          • badboy1965
            • 191
            dump all you need to usb,and do a factory reset,before you do make sure your sats not just on radio,white button second from left at top of remote (tv/radio)
            • Zizzo
              • Dec 2012
              • 56
              Thank you a lot, ok I have checked that one seems like I did set to redio only, so now I have got TV channels as well, but seems my dish is moving but am not getting any signal, because now I have AJ Channel list I have set to discq 1.0 and not USALS when am trying to set to USALS dish is moving but is not giving me any signal... and all channel showing No signal, so what should I do??
              • nibblitz
                • 1300
                Have you got the correct LOG and LAT for your location entered in your box settings?
                • Zizzo
                  • Dec 2012
                  • 56
                  Actual I never use LONG and LAT at all, I normally use USALS then dish is moving then everything is scanned that's all, but at the moment I have checked in the LONG and LAT showing 0.000 so do I really need this??and dish is moving why am not getting any signal??
                  • nibblitz
                    • 1300
                    You need to enter your LOG and LAT if you're using USALS
                    • Zizzo
                      • Dec 2012
                      • 56
                      Alright I understand now, so why before it worked and I didn't use this LONG and LAT??Also where can I get LONG and LAT...
                      • nibblitz
                        • 1300
                        Satellite Finder / Dish Alignment Calculator with Google Maps | DishPointer.com
                        • Zizzo
                          • Dec 2012
                          • 56
                          Thank you appreciate, so example if its like this
                          Latitude: 55.5029?
                          Longitude: -2.2265?
                          how do I put this number??am asking a lot of question because am new to this...
                          • mtv1
                            The Stig PT
                            • 4413
                            get a dreambox ffs take you 2 minutes to sort out the channels openbox slybox are great for one sat but a dreambox is the nuts on sat find etc or a vu don't waste time { in my opinion } setting up this when you can get a clone 500s for 20-30 quid
                            • Zizzo
                              • Dec 2012
                              • 56
                              Alright thank you for your advice appreciate, I will look around and see...because this box since I received its one month now so at the moment I will use this one then later I will change......
