are you on the vm super hub?
Skybox F3 Freezing
Sounds like the cline that you were given as part of your gift is crap. maybe when its bad try and get a 24hr test cline of one of the sites and see if it freezes.
I always have a freezes with any cline provider im on17mb broadband, but i think the issue is my adsl router Netgear DGn1000 which is the cause (mtu settings)Comment
i am reading numerous posts and thinking the same thought,
i think you have your sat box plugged into the vm hub?
kryptview also have issues more with the hd box and have advised to try using a router to see if it improves.
sat box-------router--------superhub.
all units may need powering off for 20 secs then on.Comment
Thanks but I'm not using wireless. My setup is like this:elrasho try THIS
Virgin media router > Zyxcel Poweline adapter > goes through my electric mains circuit > another Poweline adapter in the living room > skybox
I might get a really long ethernet cable and connect it straight to my super hub, but I don't want this to be a permanent setup.... Can't have an ethernet cable running through the house.Comment
Hi i am a new skybox user and i was having similar issues the recommended update of firmware fixed my problem after i had updated the firmware i had problems with channels being scrambled after flash .i had to update the channels and all works fine now. Thanks to nibblitz for the advice.Comment
Which firmware did you use? and which channel list?Hi i am a new skybox user and i was having similar issues the recommended update of firmware fixed my problem after i had updated the firmware i had problems with channels being scrambled after flash .i had to update the channels and all works fine now. Thanks to nibblitz for the advice.Comment
