Openbox S10 Ir Sensor
  • nokmond
    • Jan 2013
    • 27
    I have an openbox s10 which had an intermittent remote problem which seems to have turned permanent now.
    The remote flashes but does not change a thing on the box.
    After some searching I reckon it's probably the ir sensor in the box.
    Does anyone know where I might get a new ir receiver?
  • nibblitz
    • May 2010
    • 1300
    What flashed on the remote, was it just a red indicator light? Have you checked to see if the IR emitter on your remote is actually sending anything out? To check, aim it into a digital cameras lens, in the cameras LCD see if the IR emitter is flashing when you press a button on the remote..
    • mezzyg
      • Apr 2010
      • 158
      Re: Openbox S10 Ir Sensor
      Change the batteries, I've found that cheap batteries don't work very well with these remotes.
      Sent from my Nexus 4 using Tapatalk 2
      • slugworth
        • Nov 2011
        • 1064
        make sure no fluorescent lights or plasma tv's are interfering with the remote
