Skybox F5 can't connect to internet
  • dark5tar
    • Mar 2013
    • 26
    Hi Guys
    I just bought F5 and loaded CCcam.cfg that worked fine. When i went to scrambled channles it says s"scrambled". Tried connecting to youtube, it doesn't play. Hence I thought could be problem with connecting to internet. Can somebody help me please. I tried ethernet as well as wifi dongle both doesn't work, Signal strength shows 98%, I have DHCP on. My router is Zyxel on talktalk provider. Previously I was having DM800hd and never had problem.
    What could be the problem? box? I checked the box and found the firmaware is 19-1-2013(that would be latest I suppose).please help me
    Goto the network setup ethernet click ok turn off DHCP and then Switch it back on come out of the menu and restart the box that should cure it.
    • sb18180
      • Sep 2012
      • 355
      youtube dont work on most f5 boxes but you~~~~ does work ok so try that to see if you have internet connection to the box if it plays the videos then the problems not internet connection.
      • dark5tar
        • Mar 2013
        • 26
        Yeah I'm at work now. Will try this evening and let you guys know. I sent mail to my seller he says he tested it before despatch. This I bought of ebay uk.
        I tried you~~~~ as well last night, but that was asking for a key/pasword, don't what is this , I just send email to my seller.
        I was wondering if not wireless , Ethernet should work straight away isn't it? As my xbox, dreambox, laptop everything works on my router.
          If the seller tried Ethernet on his then the bad thing about these Skyboxes is they remember the last IP address they where on and dont change until you reset them
          • shaz6900
            • Mar 2013
            • 6
            nope nope nope you must be doing something . reflash your box to factory default settings and that will probably sort your problems out
            • dark5tar
              • Mar 2013
              • 26
              If I reflash with latest firmware ( I got this box yesterday only) If I fail the seller may not refund , isn't it?
              when i saw the network page I saw the box has got ip address, but when i saw on my router this box is not shown ,but wverything else(laptop, dreambox etc.,) was shown as connected to router
              So what is this ipaddress, could be as you said the old ip from seller ? IF so How can i re-set this?
                As i explained to you in post #2
                • Hadron
                  • 2102
                  ...I just bought F5 and loaded CCcam.cfg that worked fine...
                  What do you mean when you say that it worked fine?
                  Did you get the box & CCcam info from the same seller?
                  When you go to the "manage CCcam.cfg" page, does it show as "online"?
                  • sb18180
                    • Sep 2012
                    • 355
                    new skyboxes or newly flashed boxes are set to get internet connection by gprs by factory default. most cases you will have to activate ethernet port by menu>network local settings>network settings if ethernet is active it will have a green dot in ethernet tab also dhcp should be set to on this can be found in the ethernet tab settings. code for you~~~~ is 0000 on mine
                    • dark5tar
                      • Mar 2013
                      • 26
                      No I have code from somebody else ,which i was using my dreambox before.
                      no i won't see online, it says login then offline, keep changing those status, but never got online status
                      • dark5tar
                        • Mar 2013
                        • 26
                        sorry worked fine , was wrong, i meant that I could able to load CCcam.cfg sucessfully. I get free channels ok but not scrambled ones
                        • andy91
                          • 3583
                          Think you should keep this to pm you know cs talk isnt tolerated on dk.
                          Better than getting banned
                          Andy.
                          • sb18180
                            • Sep 2012
                            • 355
                            sounds like its no good ran out/banned for using different ip address or wrong info as stated not allowed to discuss this subject on the forum
                            • dark5tar
                              • Mar 2013
                              • 26
                              guys
                              I've checked you~~~~ it is working fine. but not youtube or scrambled ones
                              on my network settings i see like this
                              dhcp = on
                              ipaddress = 192.168.001.045
                              but when i try to connect to this ip from laptop I can't
                              in my manageccam.cfg page i see
                              N:server xxxxx xxxxx login/offline and green button
                              first xxxxx i smy pwd i suppose and next xxxx i port.
                              i see login/offline keep changing
                              what could be the problem? same cealine works on my DM without any problem
