did you reboot router and box??
Skybox F5 can't connect to internet
rebooted both router and box no use still same. really wondering what is the problem. you~~~~ working means i got internet connection ok isn't it? could be my nline not working on this?
Oh at last All guys thanks for suggestions. It's mistake from me. I went to back into my emails to see my correct nline. I entered wrong one before..... sorry ,sorryLast edited by dark5tar; 27 March, 2013, 21:07.Comment
Will be sorry when you get turfed out for cs talk,read the rules.
AndyNew Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
Hi I am new to the forum, I have read through the post and tried some of the suggestions such as changing the DHCP to off then back on and restarting the box. I have also checked the connection by trying you~~~~. I am not able to get you~~~~ either, does this mean it is a connection problem? If so what should I check?Comment
I have had an F3 for a couple of days and occasionally, the lines of ?offline?. Doing what Digicon said works, but not immediately .. I have to turn DHCP off and on a few times as it does not seem to work first time for me. I am wondering if there is a permanent solution to this or what actually causes this problem.Comment
Which connection / wifi or cable
Which box ???
No you~~~~ = no internet
Have you rebooted the router
Find you IP address with Google on a computer for your router
On the box goto /menu/network settings/ethernet settins/check your IP address is the sameComment
If I get this problem of the IP locking I turn the DHCP OFF and enter a static IP, give it a few minutes and turn the DHCP ON again.I have had an F3 for a couple of days and occasionally, the lines of ***8220;offline***8221;. Doing what Digicon said works, but not immediately .. I have to turn DHCP off and on a few times as it does not seem to work first time for me. I am wondering if there is a permanent solution to this or what actually causes this problem.Comment
Have you tried plugging your box into the router directly and then make sure your network settings are set to accept Ethernet?
If using wifi, make sure you add the password and save the settings. 802.11g is unstable as its based on the environment it is in. So the skybox might just be loosing connection to the box if its on wifi.Comment
