openbox s9 weird
  • pspmixer
    • Jun 2009
    • 750
    openbox s9 weird
    got a openbox s9 which works in my house with sealion but problem is when take to friends house, bbc and itv work but nothing else works get 82 signal on both them channels but when view any other channels says no signal and on the signal screen says 42% in grey not colour bar, any advise how to sort this work be great thanks
  • andy91
    • 3583
    Guessing ip is ok.
    Upload new bouquet and see if that sorts it.
    Andy.
    • pspmixer
      • Jun 2009
      • 750
      yes upto date everything
        Could be dish alignment as both the ITV and BBC channels are on 2F and 1N respectively both very powerful birds
        • pspmixer
          • Jun 2009
          • 750
          when tried vu box on same line it works no problem in friends house, so I thought it could be his dish cables, might swapped to different port on lnb or could run another new wire from dish to box, as thinking the wire might of worn down on it too
          • slugworth
            • Nov 2011
            • 1064
            probably trying to run more than 1 receiver on a quad lnb syndrome.
            1 receiver at a time should work fine if the lnb and aiming are the same as yours.
            • pspmixer
              • Jun 2009
              • 750
              I have 4 boxes in mine all running at one now don't stop working like this one does
              • andy91
                • 3583
                I've 2 boxes running i wouldn't agree with the previous post.
                Tuner could be another answer as im guessing your other box is a better spec.
                Have you thought about trying to change the firmware for what its worth.
                Andy.
                • slugworth
                  • Nov 2011
                  • 1064
                  one location has something not the same
                  • pspmixer
                    • Jun 2009
                    • 750
                    Andy.
                    whats best for openbox s9 then
                    • pspmixer
                      • Jun 2009
                      • 750
                      any updates on this
                      • Hadron
                        • 2102
                        When you say that BBC & ITV work but nothing else, do you literally mean nothing else whatsoever?
                        I was wondering whether it may be due to the vertical transponder problem that some openbox/LNB combinations suffer from, but you should still get more than just BBC & ITV.
                          If it is an LNB problem then find out what make you have on your own dish and what is on your friends, Typically its the Zinwell branded ones that cause a problem with the Openbox although out of all the receivers i tested on that brand of LNB it is only the Openbox that suffers
                          • pspmixer
                            • Jun 2009
                            • 750
                            no I mean like all free view channels work
                            we both have same dish and lnb by sky
                            • Hadron
                              • 2102
                              So it's only a problem with $ channels.
                              That's odd. Thought it might be a network problem, but if it was, it would show "scrambled", not "no signal".
