lnb splitter
  • scoobydoo10uk2000
    • Mar 2013
    • 12
    lnb splitter
    I noticed that ebay sell splitters for sly wires so i could hook up another box. But i was also told that each box needs to run directly from the lnb. So which is which. Can i use one of these splitters ?? Thanks for any help on this
  • BigfatPaulie
    • Dec 2011
    • 203
    No... You can't!
    Sent using Tapatalk
    • TheCoder
      • Jun 2011
      • 693
      You can run many boxes from a single quad lnb by using a device that fixes each of the four outputs into one of the four possible states (15v/no tone, 15/tone, 18v/no tone and 18v/tone). At the box end you would then need to use the 'opposite' device to either recombine the signal or, more likely, route the box to the proper one of the four lines.
      This is the kind of device often used in distribution system where many households can be supplied by one single quad lnb/dish (ie flats etc)
      • rugito
        • Apr 2013
        • 10
        What are these devices called???
          What lnb splitters there called splitters hope this helps...............
          • rugito
            • Apr 2013
            • 10
            so i could use a splitter to join the quad lnb into one wire and then use another splitter to split the one wire into 4 for my boxes.... or did i completely misunderstand
            • digicon
              • 8261
              The Quad LNB has four separate outputs that can feed 4 receivers independently from one another so i am unsure why you would want to join them all together and then split them
              • bbb_uk
                • 429
                Each box does need to have its own feed directly from the LNB.
                Splitters wont help you and distribution systems are complicated for average household.
                • cactikid
                  • 12017
                  and with sat boxes sending voltage though their cables best to use 1 lnb feed to 1 tuner,nasty if you fried your tuners.
                  • mahrkpat
                    • Jun 2012
                    • 510
                    You can't use a splitter like you do on a coax cable, if you have two tuners then each tuner needs to have its on lnb feed or if sharing a lnb feed then one must be off, 2 tuners can't use same lnb at the same time. If both tuners (if it works) are on you will find that one of the tuners will only be showing channels that are on same transponder as the other tuner is tuned to, I hope I have not confused anyone.
                    • sb18180
                      • Sep 2012
                      • 355
                      NO SPLITING COAX!!! this is not cable
                      • TheCoder
                        • Jun 2011
                        • 693
                        You can do it using the technique I described above and another technique that remaps each of the outputs to a new frequency range before feeding the lot down a single coax but its not really practible for standard home setups. The methods are used extensively for distribution systems or where there is excessive cable distances (its common in certain parts of scandanavia where the dish could be located several km from the receiver).
                        Unless you have some specialist requirement its probably easier to just dismiss the idea.
                        Originally posted by sb18180
                        this is not cable
                        As long as you take the control voltages and signals into account there's not really a lot of difference. In the end its all just signals down a bit of coax. Use the proper interfaces and you could treat sat in a similar way to cable with little problem if you were so inclined.
                        • icaruspr
                          • Apr 2013
                          Buy a 3 x 4 switch or a 3 x 8
                          • BigfatPaulie
                            • Dec 2011
                            • 203
                            You can do anything, if you throw enough money at it...
                            The point here is, one tuner needs one lnb port, twin tuner box needs two ports and so on.
                            Sent using Tapatalk
                            • sb18180
                              • Sep 2012
                              • 355
                              you will still only be able to use 1 satbox at a time correctly
