Thanks matr. I really do appreciate your help. You highly recommend the homeplug over wifi usb? How do they work? Is it one plug connected to router instead of normal and one to box? Any idea why my router is not connecting to skybox. My username is coming up but keeps timing out when typing in password. should I take password off? Would sortting out wifi be the final step to watching all the channels? also whats all this ccam and gift stuff?
Skybox f5 usb wifi not working with BT homehub
For sure homeplugs are better than WiFi as WiFi just glitches all the time. Can't really chat about gifts on forum but cccam is an emulator that allows you to use a gift to see channels.
One homeplug connects to router and other connects to skybox f5 in Ethernet port at the backComment
easy answer no..you also need the last bit in your question......on the box
also you have posted this same question in a lot of threads.....a read of the rules come's to mind regarding your questionsComment
Both should read the rules. No suggestion of card sharing and don't flame members so both ops check the rules,
AndyNew Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
hi changed my wireless settings in the advanced settings through the home hub manager from WPA & WPA2 encryption to WPA2 encryption fixed my issue today using a wifi dongle from ebay WIFI 150MBPS WIRELESS ADAPTOR 802.11 B/G/N HIGH GAIN AERIAL LAN USB DONGLE | eBayComment
