Glitching/freezing/scrambled/....NIGHT TIME ONLY ???..line or Internet??!!
  • Nutty34
    • Feb 2013
    • 130
    #16
    Originally posted by mahrkpat
    If OP was experiencing problems all day long and not just the evenings then I would agree with you but these days with the always on internet connection programs like skype etc.. are always on as well, I don't know the OP but I doubt they would instantly start doing some heavy downloading or streaming just as evening arrives, although I could be wrong.
    Not just a case of that mate, many ISP throttle their connections ( including Virmin these days) and in particular after 6pm.
    Posted using Tapatalk for IPad.
    • sb18180
      • Sep 2012
      • 355
      #17
      some people in the uk do actually work/school/uni during the day i know its hard to believe and come home and all switch on thei internet connected devices/phones/pads ect routers get clogged everything runs slow then and slow is not good with satboxes freeeeeezes and as stated ips throttle at peak times
      • Nutty34
        • Feb 2013
        • 130
        #18
        Virmin actually throttle up to as much as 75% these days.
        • sb18180
          • Sep 2012
          • 355
          #19
          i know i get over 100Mb/s middle of the night and sometimes only 50Mb/s tea time and i dont do much downloading these days so there is no way i reach the limits to be traffic managed. its a scam these advertised speeds are. they dont drop my bill by 50% peak times
          • Nutty34
            • Feb 2013
            • 130
            #20
            Ha ha .... Don't think they will ever drop the bill accordingly mate
            • mahrkpat
              • Jun 2012
              • 510
              #21
              The data stream to and from a server is very small and some people use a 3G dongle to connect their stb to the internet without having any problems with freezing/glitching try a ping test at peak time anything under 80 should be fine.
              • cactikid
                • 12017
                #22
                are you using a super hub with wifi mode?
                • Nutty34
                  • Feb 2013
                  • 130
                  #23
                  OP is using wifi to connect on his box, the wifi facility on these boxes are notorious for dropping connections. I would try hard wired or home plugs myself which is easier said than done when running off a mifi dongle.
                  • Nutty34
                    • Feb 2013
                    • 130
                    #24
                    Mate he is using a mifi dongle, I suppose my posts re Virmin were a little off topic, I was just making members aware of the throttling going off currently with Virmin.
                    • cactikid
                      • 12017
                      #25
                      anything to upset the customer,but as everybody has told him go hard wired or home plugs.
                      • mahrkpat
                        • Jun 2012
                        • 510
                        #26
                        Did a little research mifi is by 3 and they do seem to throttle at peak time 6pm to 12am and ping can go as high as 300ms which is bad will lead to freezes and glitches. Could be time to change provider if not in a contract.
                        • Nutty34
                          • Feb 2013
                          • 130
                          #27
                          Well there you go ! As suspected an ISP issue
                          • sb18180
                            • Sep 2012
                            • 355
                            #28
                            WOW that and wifi dongle on a f5= major disaster hes lucky to be getting any sort of moving image. footy match= 90mins bet he gets to watch 10 seconds of it
                            • boylan
                              • Oct 2011
                              • 128
                              #29
                              I had this problem using homeplugs and wifi......... so decided to get a telephone extension lead and have my router behind my television and i have had no freezes jumps or anything since, nearly a week a no stops
                              • car147
                                • Apr 2013
                                • 13
                                #30
                                In comparison, my F3 (wired to router, BT) has the same issue from early morning to early afternoon. then perfect at the busiest times.
