That sky list is great...formed a fantastic base file for me to do my regional tweaks....THANKYOU
Cwaite Sky Numbered Channel List **Discussion** Thread
I can honestly say that this is the best channel list I have come across, (dogs dodahs)Originally posted by tony2803great channel list,works great on my f3.thanks
set up to my region and set blank channels to skip my f3 is now working like a sly hd box
once again thanks. -
Why not have a go at moving them yourself then you can have them just where you want them.
All of the channel list are done as a general list to suit most needs.
You can please some of the people some of the time but not all of the people all of the time. Thats how the cookie crumbles.Comment
Hi Andy,
This is regarding SkyBox F3 buddy.
1. Goto Menu then Channel Edit.
2. Tick the blank channel's you want to skip.
3. When done select the bottom Icon on the right called "Skip"
4. Then press exit and confirm "Are you sure to save" YES.
5. Reboot box and Done
You can now Skip the Blank channel's as you cycle through your listing's.
Cheer's Tony
Humax FoxSat-HDR
Great HD/SD Box with 500GB HardDrive
Manhatton HH-120 42E-30W
Triax 88cm 0.3db
SKYBOX F3
HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
Intel Core i7 [email protected]
MSI R7970 Twin Frozr Boost EditionComment
it cannot get any better than this,this d/k member should be d/k knighted for his work on his contribution on this subject.great thanks, Sir sattv5.New Channels & Moved Frequency Channels updates 27/6/2013
Cruzr (Now on Sky EPG moved to Channel 943)
Box Office HD 2 channel 702 removed as no longer in use
Weddingtv Channel 1072 removed as left Astra 28a
News 18 India (not on Sky EPG yet) Channel 1072
Other Channel list ammendments:
All favourites now in order and updated (you may have to change labels on them to reflect this)
(See favourites List included in zip)
MTV Channels correct Audio Pids Used
HD Movie Channels correct Audio Pid set to Defaults
Blank channels now skipped when scrolling through channel list
TP_Prog.DBS file extension changed to lower case (.dbs)Last edited by tony2803; 29 June, 2013, 02:10.Comment
