Cwaite Sky Numbered Channel List **Discussion** Thread
  • ts398im
    • Jul 2013
    #31
    Thank you . sky sports ashes now in hd.
    • P&D
      • 2685
      #32
      I have updated sattv5
      list many thx for the upload
      Only sports channels sorted in HD order
      edited all the double sd channels out
      great if you only watch the sports
      • goldberg
        • Jul 2013
        • 18
        #33
        Hi,
        Is there a way to have a full channel list and not having to select favourites, so I could just press a number and it would go to that channel based on this listing? Otherwise I have to select favourites and it gives those category channels only.
        • satboxman
          • Jan 2013
          • 12
          #34
          have up dated with new list but cant get
          ss 1 hd
          ss ashes
          ant a lot more just says no signal but box works ok on other channels I'm using a f5 if it was tuner then would all channels be no signal not sure if they have changed the frequency agen to crack us all up
          • AndyX
            • Mar 2013
            • 14
            #35
            Originally posted by sattv5
            The Sky HD Channel list has BBC1, BBC2, ITV, Channel 4 & Channel 5 (Channels 101 to 105) as the SD Versions
            The Full HD Channel list has BBC1, BBC2, ITV, Channel 4 & Channel 5 (Channels 101 to 105) as the HD Versions
            everything else is the same.
            On the 4th July Sky HD Odered TP_Prog.dbs Update.zip the 101 to 105 channels are SD correctly but where the HD versions should be, they are also SD. For example 141 should be bbc 1 hd but is the sd one etc.
            Thanks for all your hard work.
            • sattv5
              • May 2013
              • 376
              #36
              Originally posted by goldberg
              Hi,
              You Don't have to select favourites as these are full channel lists. If you have a look here Sky Guide TV Listings - Sky
              there is a number under the channels, press this in to your sky box and the correct channel will come on.
              • sattv5
                • May 2013
                • 376
                #37
                ss 1 hd
                ss ashes
                If you tune to the channel thats not working and press the info button on the remote control 3 times, you will have a screen that comes up that lists the transpoder details:
                Sky Sports 1 HD (11798/H/29500)
                Sky Sports Ashes HD (11720/H/29499)
                if the details are the same the channels are correctly setup on your box.
                • sattv5
                  • May 2013
                  • 376
                  #38
                  Channels updates 5/7/2013
                  Sky HD Ordered lists only needed updating today, Full HD lists still up to date. (Channels were put in wrong place on Sky HD List)
                  Sky HD fixed Channel list:
                  BBC1 HD Channel 141
                  BBC2 HD Channel 142
                  ITV HD Channel 178
                  Channel 4 HD Channel 230
                  Channel 5 HD Channel 171
                  • mrcooke
                    • Jan 2013
                    • 7
                    #39
                    hi lads
                    im using skybox f3 firmware (3601HD_10_05_2012_073A) i deleted my old channel list then downloaded 5th July Sky HD Odered TP_Prog.dbs Update.zip list extracted file and put it to root of usb stick,
                    went to tool, upgrade by USB, upgrade mode (music files), select and upgrade(TP_PROG.dbs) then upgraded it and when i check info i get file not found. ANY HELP PLEASE
                    • tony2803
                      • 266
                      #40
                      [QUOTE=mrcooke;2021836]hi lads
                      went to tool, upgrade by USB, upgrade mode (music files), select and upgrade(TP_PROG.dbs) then upgraded it and when i check info i get file not found. ANY HELP PLEASE[/QUOTE
                      reformat usb stick in fat32 I had same problem mine was formatted in ntfs,reformatted fat32 put file back on stick and went onto f3 straight away,remember to put tick on tp_prog.dbs by pressing ok and then yellow button to upgrade..
                      • mrcooke
                        • Jan 2013
                        • 7
                        #41
                        usb is fat32 i used same usb to reinstall old channel list and went ok, do i need to factory delete my old channel list or just delete it and is their anything else im doing wrong ?
                        • tony2803
                          • 266
                          #42
                          usually you would not have to delete old channel list,as the new list that you are installing will over write old list,try deleting channel list and do a blind scan,then try re-installing tp_prog.dbs
                          into box and if it goes in reboot box and it may work.
                          • genam
                            • Apr 2013
                            • 176
                            #43
                            Unless you are just updating an existing SATTV5 list you MUST delete the existing channel list within the box........then upload the new list.......otherwise you end up with an endless array of channels.
                            • moc2812
                              • Jun 2013
                              #44
                              if you delete your old channel list DO NOT DO A BLIND SCAN. I did a blind scan last week and then put a channel list on and bricked my box. I rang the box supplier and he walked me through the steps using a rs232 cable to reflash the box connected to a pc. he explained to me that doing a blind scan then installing a channel list can and will in most cases brick the box. mine is now fully working again. I now delete the channel list that is installed then switch box off then turn back and install new channel list then switch off then back on and all is ok. if you get a corrupted favourites list that shows movies in for example kids you have to do a factory reset which is in tools then switch off then turn back on and install favourites list again and they will show in the correct order
                              • durasoft
                                • 57
                                #45
                                hi lads
                                Hi MrCooke,
                                Just check to make sure that the file TP_PROG.dbs is not in CAPS at the end ie TP_PROG.DBS as it wont reconize it. The file extension should be in lowercase buddy.
                                Regards Tony
                                Humax FoxSat-HDR
                                Great HD/SD Box with 500GB HardDrive
                                Manhatton HH-120 42E-30W
                                Triax 88cm 0.3db
                                SKYBOX F3
                                HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
                                Intel Core i7 [email protected]
                                MSI R7970 Twin Frozr Boost Edition
