Cwaite Sky Numbered Channel List **Discussion** Thread
  • durasoft
    • 57
    #226
    Hi Sattv5,
    Great list again, thanks.
    SS Ashes HD can't view tried re-scan tp list for that freq no joy :-(
    SS Ashe SD is fine and others on the same tp is good.
    Just doing a network scan and see what I can find and let you guys know.
    Regards Tony
    Humax FoxSat-HDR
    Great HD/SD Box with 500GB HardDrive
    Manhatton HH-120 42E-30W
    Triax 88cm 0.3db
    SKYBOX F3
    HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
    Intel Core i7 [email protected]
    MSI R7970 Twin Frozr Boost Edition
    • sattv5
      • May 2013
      • 376
      #227
      Originally posted by durasoft
      Hi Sattv5,
      Regards Tony
      I've checked both the channel lists again and it's still working mate, give the channel another try
      • hassan1994
        • Aug 2013
        • 5
        #228
        Hi, i'm new to all of this. Anyway, I've got my SkyBox F3 with channels from some shop and they provide the service/channels for me (12 months). If i get the channel list, it wont effect my service will it? Like frequencies and server stuff? I just want to triple check in case i mess up..
        • bbb_uk
          • 429
          #229
          It will replace the channels the shop provided. Occasionally, the favourites may not change when channels updated (ie favourites stay as they are now) but I'm sure Sattv5 sorted this occasional problem. You should be able to rename your favourites if this does happen.
          It will not mess with your service in anyway unless you reset back to defaults, etc
          • hassan1994
            • Aug 2013
            • 5
            #230
            Sooo I shouldn't go through with it?
            • sattv5
              • May 2013
              • 376
              #231
              Yes, it's important to update your channel list when they move
              • sattv5
                • May 2013
                • 376
                #232
                Moved Frequency Channels Updates 30/08/2013
                Vintage TV (Channel number 369)(Moved frequency) 11.261 H 27500
                Bid (Channel number 654)(Moved frequency) 11426 V 27500
                Inspiration (Channel number 587) (Moved frequency) 11307 H 27500
                Sony Max (Channel number 800) encrypted $ Flag now set
                Sky SuperheroesHD (Name fixed now) (long channel name issues with skybox/openbox)
                • hassan1994
                  • Aug 2013
                  • 5
                  #233
                  So it's safe to do? Only the channel list will change but they'll all work? Are asian channels included?
                  Sorry that I'm being such a pain in the ass but my dad paid for the service and its my head if it messes up :/
                  • sattv5
                    • May 2013
                    • 376
                    #234
                    Don't worry about being a pain as everyone has to start somewhere, at least your asking questions to make sure you do it right.
                    Follow the instructons below:
                    How to Dump existing firmware & All settings
                    1 Place Memory Stick in Skybox
                    2 Press menu on the skybox remote
                    3 Go to Dump by USB
                    4 Go down to Start & Press OK
                    5 Press OK on Option 1 & 2 so there is a tick next to 3601HD_Backup.abs & System Settings
                    6 Now Press the yellow button to Dump
                    7 After a few seconds the screen should say Dump all finished Press info key for results
                    8 press info key on the remote and make sure that 3601HD_Backup.abs & System Settings have the word OK after them
                    9 Now that it's finished you will have a file named 3601HD_Backup.abs on your memory stick
                    10 Copy the file 3601HD_Backup.abs from your memory stick to SOMEWHERE SAFE (DO NOT LOSE IT), email the file to yourself if you have to.
                    How To back up existing Gift/Server/*line
                    1 Place a memory stick in the usb port on your skybox
                    2 Go to menu on the remote control and find the option Dump by USB and select it
                    3 Where it says dump mode change to Misc Files, scroll down then and click on Select & Dump
                    4 At this menu press ok on the remote so that CCcam.cfg (CCcam Plug) has a green tick next to it & newcamd.list(MGcamd.plug) has one as well
                    5 Now Press the yellow button on the remote
                    6 After a few seconds the screen should say Dump all finished Press info key for results
                    7 press info key on the remote and make sure that CCcam.cfg (CCcam Plug) has the word OK after it & newcamd.list(MGcamd.plug) says ok as well
                    8 Exit the menu back to the normal tv screen
                    9 Remove the memory stick from your Skybox
                    10 Place the memory stick in your PC Now, there should be a file on there called CCCam.cfg & Newcmd.list
                    11 Copy the file CCCam.cfg & newcamd.list from your memory stick to SOMEWHERE SAFE (DO NOT LOSE IT), email the file to yourself if you have to.
                    You can now install the channel list as you have backups of your whole box in case anything ever goes wrong with it.
                    All the asian channels are included on the list. If you look at the link below the channels follow that format and the numbers listed under each channel.
                    Sky Guide TV Listings - Sky
                    • terrytibbs1
                      • Nov 2011
                      • 6
                      #235
                      Hi Guys
                      I upgraded (well I thought I did) my openbox.
                      I put the new channel list on it and now none of the channels work not even the FTA, before I did the upgrade on channel list it was all working fine. Any ideas what could possibly be wrong?
                      p.s. ive also tried a satellite scan but still no joy
                      • Asudha
                        • Jun 2013
                        • 20
                        #236
                        Channels not working:
                        Sky 3D (170)
                        Luxury Life (273)
                        holiday+crise (284)
                        Sky Disney HD (305)
                        CI+ (554)
                        The Dept Store (681)
                        The Mall (682)
                        Sky Insider HD (889)
                        HD Retail Info (101)
                        Akaal Channel confirmed Sly EPG number 858
                        • dj1891
                          • Jul 2013
                          • 46
                          #237
                          Can I ask what exactly is the latest channel list? The last one I see is a month old
                          • sattv5
                            • May 2013
                            • 376
                            #238
                            Sky 3D (170)
                            Luxury Life (273)
                            holiday+crise (284)
                            Sky Disney HD (305)
                            CI+ (554)
                            The Mall (682)
                            Sky 3D (170) works in daytime mainly most days starts 9am
                            Luxury Life (273) works from 9am to 2pm
                            holiday+crise (284) working fine
                            Sky Disney HD (305) works daytime & evening only not 24 hour channel
                            CI+ (554) working fine
                            The Dept Store (681) working fine
                            The Mall (682) working fine
                            Sky Insider HD (889) there's nothing on the channel at the moment
                            HD Retail Info (101) Working fine
                            Akaal Channel confirmed Sly EPG number 858 (I only move the channels from temporary place when they actually get added to the Sky HD EPG) should be added to EPG late September
                            If you have a look here, you can see what's on the channels Sky Guide TV Listings - Sky
                            • sattv5
                              • May 2013
                              • 376
                              #239
                              the latest channel list was yesterday 30th August 2013 and is the first post in this thread:
                              • Hadron
                                • 2102
                                #240
                                ...Luxury Life (273) works from 9am to 2pm...
                                Hmm...as I mentioned in the other (AJ) thread, I still cannot receive this channel (not that I'm that interested!).
                                Right now (11.15am) I am getting "scrambled" message & no info on the EPG.
                                Edit...just looked at the Sky guide link in your post. Looks like it's broadcast times are just 6am to 8am. Hardly worthwhile. LOL.
