Cwaite Sky Numbered Channel List **Discussion** Thread
Here is another update to the Sky Numbered Channel List, I have been busy tonight!
The changes are as follows:
Sky 3D Fixed
MTV Live fixed - was showing Chatbox
Various Music Channels Fixed (Chartshow TV, The Vault, Scuzz, Starz TV, Chartshow Dance, Bliss)
Showcase and Showcase 2 Fixed
BBC Three SD Fixed - was showing CBBC
NHK World HD Fixed
RT HD Fixed
Hidayat TV Fixed - was showing Horror +1
ITV +1 Granada Fixed
Added Sky Box Office 36 to Channel 737
Added MUTV HD to Channel 453
As usual if anyone notices any missing channels or channels not working please let me know, also if any channels are numbered wrong, please let me know.
Here is the latest update of Sattv5's (updated by cwaite) Sly channel numbered list
changes since last update
Anytime 1 & 2 Removed
Removed Anglia South
Dave Changed From Irish Version to UK Version
Added Missing PMT and PCR and Txt information for ITV Regions
Updated Names for Channel 4 and Channel 5 Regions
Updated Radio Stations and put them in the same order as on Sly
Hope this is all OK, as always if you notice something wrong with the list please let me known and I will do my best to correct it.
Thanks for all the messages of support for this, I am not sure how much I can commit to keeping this up to date but I will try my hardest, if Sattv5 is not able to keep the list up to date then I may well ask the mods if I can start a separate thread and get them to make it a sticky, as this is what many of the messages have requested.
Here is todays update, which has added the BBC Red Button Channels 981-985
Fixed Star Life, Rishtey TV, Ahlulbayt TV, Psychic Today, Lucky Star and Changed Discovery Channel from Ireland to UK version
[ATTACH]269246[/ATTACH]
As always if anyone notices any channels that are missing or not working or numbered incorrectly, please let me know.
if your continuing his work with his blessings we can change the name of this thread, or close this thread and if he decides to continue reopen it, if you start your own thread please try your best to update it or we will have 2 "dead" threads.
At present I do not officially have Sattv5's blessings to continue his work, although I did say that if Sattv5 has any issues with me updating his list then I would gladly remove the list, so far I have not heard either way from Sattv5, perhaps if I have not heard anything from Sattv5 in a few weeks time then I will start a separate thread for this.
BBC RB0 Added to 980 (broadcasts 19:00-05:30 channel is shared with CBBC at other times)
BBC RB HD Added to 986 (broadcasts 19:00-05:30 channel is shared with CBBC HD at other times)
CNN moved frequency
EWTN renamed EWTN Catholic
Great Work Mate- you are doing an incredible job and I think you are going to make a lot of friends on DK
don't forget to fix the non working Asian Channels please
The asain channels are all working. If you have noticed anything please give example so any improvement can be made to what is already an excellent list
After you have installed the latest TP_Prog that you want to use, go on the Menu, Single Satellite Search, and complete an Accurate Scan. After its finished, exit, and turn the box off and on. Usually sorts the no signal channels.
I have updated Sattv5 (updated by cwaite) Sly Numbered list:
Changes are:
Non working HD Channels are now skipped when browsing up/down channels
Comedy Central changed from Irish Version to UK Version (Thanks to JB0509)
QVC Beauty Changed Frequency
Geo TV Now Scrambled Fixed this
The list can now be found at my new website click the link below:
Reason: Sorry No Links
...The list can now be found at my new website click the link below:
Just read your instructions for installing.
In all the time I have been installing channel lists on various Openboxes/skyboxes I have always just put the box into standby & then back on again, rather than pulling the power plug. I've never had any problems doing it this way.
Also, it might be worth adding to the instructions, to press the info button after installing to make sure that the list installed correctly. It should take around 10 seconds for correct installation. If it only takes a second or 2, then it wouldn't have installed properly.
