Is there an official instruction guide to updating the channel lists? I use a F5S box and I can see both sides of the issue. What I have noticed is that if I delete the existing channel list first then upgrade to a new one then I have to reboot the box manually as the box displays no channels on the front display and on the on screen menu display but if I just upgrade the box with a new list without deleting the old one then my box reboots automatically which would seem to indicate to me that it is the logical and correct method because it does it automatically. I haven't bricked my box yet and saying that I don't want to either but I would prefer to know which is the correct official method.
Cwaite Sky Numbered Channel List **Discussion** Thread
I don't think there is an official way of doing it, i guess it's you pay's your money you take your chances with these boxesIs there an official instruction guide to updating the channel lists? I use a F5S box and I can see both sides of the issue. What I have noticed is that if I delete the existing channel list first then upgrade to a new one then I have to reboot the box manually as the box displays no channels on the front display and on the on screen menu display but if I just upgrade the box with a new list without deleting the old one then my box reboots automatically which would seem to indicate to me that it is the logical and correct method because it does it automatically. I haven't bricked my box yet and saying that I don't want to either but I would prefer to know which is the correct official method.Comment
I did exactly as your instructions said and now my skybox f 5 just says 'Load' and does not do anything?Comment
So after following the instructions my box now says 'Load' no time when in standby and does not respond with the remote, have I now bricked the box???????Comment
Yes mate ...now you need this thread....Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
(Thanks to Sattv5 for his lists). I note his comment about deleting existing list before installing new list. Can someone remind me how to 'delete' please? (F5 and F5S).Comment
Menu > Edit Channel > Delete All and answer yes when prompted.
I then personally reboot and install list and reboot again if it doesn't do it automatically.Comment
Everything's been quiet over the last 10 days or so with only 1 channel on the list moving frquency (HD Retail Info) so this update is really just correcting EPG position, channel rebranding and sorting out missing favourites.
Moved Frequency Channels Updates 24/10/2013
TLC +1 (Channel number 195) Moved EPG Position to 154
Quest (Channel number 154) Moved EPG Position to 167
Quest +1 (Channel number 167) Moved EPG Position to 195
Geo UK (Channel number 815) Now encrypted again $ flag added
HD Retail Info (Channel Number 1001) Moved frequency to 12324 V 29500
MTV +1 (Channel 160) Default Audio PID Corrected for channel (2358)
MTV Trax (channel 1074) Removed as it has been a black screen for several months now
Greatist Hits Tv (Channel number 378) Rebranded NOW Music
Kiss (Radio Section) Removed as Dual transponder leftover
Magic (Radio Section) Removed as Dual transponder leftover
Real Radio (Radio Section) Removed as Dual transponder leftover
Smooth (Radio Section) Removed as Dual transponder leftover
Regional variants of HD Channels added to Regional Favourites Group
Moved Frequency Channels Updates 26/10/2013
Zee Cinema (Channel number 791) wrong location on EPG moved to Channel 790
Ary Ent (Channel number 790) wrong location on EPG moved to Channel 791
information given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix ItComment
..................,both saying scrambled,so have updated myself with new freq,thanks anyway
