Cwaite Sky Numbered Channel List **Discussion** Thread
BT Sport HD is on 11973V 29500 your list is showing the old HD frequency that changed on 17th August 2015, I don't think you have the latest list loaded on your box, please tune to channel 1 (not 101) and post the number that appears in the channel name, this will enable me to establish if you have the latest channel list.If you need help installing channel guides or have a problem, take a look at my video guides
https://www.youtube.com/playlist?lis...GHAAdpsKXqtadCComment
Hi cwaite,this is odd to me now.
I updated my v8s box earlier using the latest update that you put here earlier today.
After doing this update,my bt sport channels were visible again in non-hd,so the latest update 2015 - 08 - 20 installed ok.
I have just done as you asked,and gone to channel 1 and the number that appers is 06082015
As I posted earlier,i have managed to get the bt sport hd channels now.
Do you know why my channels have updated with todays list but channel 1 is showing 06082015
Thanks for all your effort in providing a great list,and updatesComment
If channel 1 is showing 06082015 you definitely don't have the latest list on the box its 2 weeks out of date, have you unzipped the file TP_Prog.dbs to your fat32 formatted USB drive? Before downloading the list to the box?If you need help installing channel guides or have a problem, take a look at my video guides
yes I unzipped the tp prog dbs to my formatted usb.
before doing this today,i did not have bt sport sd or hd.
after doing the update I had bt sport sd,and then done a manual search and this got me bt sport 1 hd bt sport 2 hd and bt sport Europe hd.
so the update must have worked.
I will look into it in the morning,could it still be showing 06082015 because I did not delete the channel list before updating the box with todays listComment
The new channel list should overwrite the current one, but I always recommend deleting channels on the box before installing a new list. That way you know for certain that the new list has installed properly.yes I unzipped the tp prog dbs to my formatted usb.
Also, when you put the new channel list on the USB stick, did you delete the previous TP_prog.dbs file first? If not, did you make sure that you selected the option for windows to replace the previous file & not keep it?
When you installed the latest list, did it show OK when you pressed the Info button?Comment
I have not removed my usb from the box since I updated it,and as I said,before updating,i didn't have any bt sport channels.
After updating,i had the bt sport channels,so update must have worked,but number 1 was showing 06-08-2015.
Without removing the usb,I have just gone through the updating process again,and it now shows 20-08-2015
Weird or what.Comment
Neither working on my box will check them out tomorrow, thanks for pointing this out.If you need help installing channel guides or have a problem, take a look at my video guides
I am away at the moment but have managed to update the Adult version of the list to reflect the new BT sport HD changes, please see my website to download, I will upload to the forum when I get home.If you need help installing channel guides or have a problem, take a look at my video guides
