Hi, I have a s11 that sticks on boot and gives no display, a quick search on digital-kaos suggests next step would be flash the box which is something I have never done. So I look on eBay for a cable and see that most are male to male so I thought I would check the box only to find it takes a female, but then I came up against a bigger problem no laptop in my house has a rs232 socket, what do I do?
rs232 cable
If most of the cables you found were Male to Male then you were searching for the wrong cable.Hi, I have a s11 that sticks on boot and gives no display, a quick search on digital-kaos suggests next step would be flash the box which is something I have never done. So I look on eBay for a cable and see that most are male to male so I thought I would check the box only to find it takes a female, but then I came up against a bigger problem no laptop in my house has a rs232 socket, what do I do?
It has been emphasized over & over again that the cable needs to be a null modem cable and not a straightforward serial cable. If you search for these on Ebay you will find that the vast majority are female to female.Comment
Yes mate that will do fine
just might take a bit longer but it will do the job
all the answers you will need is in this thread....Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
