I am trying to see/save Cccam.cfg from F3 box, but evry time I save Cccam.cfg it save's 0kb.
How do I save Cccam.cfg or display Cccam.cfg on F3 box.
Hi Kivish,
Make sure your USB is formatted fat32
Go into menu and select Dump By USB
Change Dump Mode to Misc Files then press Select & Dump
Select No.3 CCcam.cfg and press ok so it ticks it.
Then press the Yellow Button to save it to your USB Stick
It then should say 100% "Dump All Finished. press "info" key for result.
That's your Line backed up hopefully.
It's only 1 line of data so it shouldn't be a large file anyway about 1k
I use NotePad to open the file to view it or edit it.
Hope this helps you out.
Regards Tony
Humax FoxSat-HDR
Great HD/SD Box with 500GB HardDrive
Manhatton HH-120 42E-30W
Triax 88cm 0.3db
SKYBOX F3
HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
Intel Core i7 [email protected]
MSI R7970 Twin Frozr Boost Edition -
Hi Kivish,
Regards Tony
I have the same problem. I too have a blank file with 0 bytes. There is nothing to view with Notepad, only an empty page??Comment
