How do I save Cccam.cfg or display Cccam.cfg on F3 box.
  • kivish
    • Jul 2013
    I am trying to see/save Cccam.cfg from F3 box, but evry time I save Cccam.cfg it save's 0kb.
  • durasoft
    • Aug 2008
    • 57
    Hi Kivish,
    Make sure your USB is formatted fat32
    Go into menu and select Dump By USB
    Change Dump Mode to Misc Files then press Select & Dump
    Select No.3 CCcam.cfg and press ok so it ticks it.
    Then press the Yellow Button to save it to your USB Stick
    It then should say 100% "Dump All Finished. press "info" key for result.
    That's your Line backed up hopefully.
    It's only 1 line of data so it shouldn't be a large file anyway about 1k
    I use NotePad to open the file to view it or edit it.
    Hope this helps you out.
    Regards Tony
    Humax FoxSat-HDR
    Great HD/SD Box with 500GB HardDrive
    Manhatton HH-120 42E-30W
    Triax 88cm 0.3db
    SKYBOX F3
    HD-Fix F/W from www.skybox.cc - CCcam/MGcam/Newcamd
    Intel Core i7 [email protected]
    MSI R7970 Twin Frozr Boost Edition
    • hackitt
      • 68
      Originally posted by durasoft
      Hi Kivish,
      Regards Tony
      I have the same problem. I too have a blank file with 0 bytes. There is nothing to view with Notepad, only an empty page??
      • alienkargo
        • Jan 2014
        • 63
        try deleting it and putting it back on from where you backed it up on your pc.
        • hackitt
          • 68
          I re-formatted usb stick to fat32, dumped new cccam.cfg onto stick and then re-inserted into pc, still nothing to view. and shows 0 bytes. I don't know what else to try.
