I get some channels and some say no signal.
  • poyzy
    • Aug 2013
    • 31
    Hi Thanks in advance.
    I'm getting a weird thing happening with my f5 box. On some premium channels i am on getting around 5% signal strength and no signal and some Premium channels work absolutely fine.. WHY?
    I have tried a different box from a friend and sames channels that have no signal on my box work fine on the other box.
    strange
    can some one help Plz.
  • P&D
    • May 2010
    • 2684
    Hi it could be firmware but i would guess its the F5 box nacked
    • McrRed
      • Jul 2010
      • 86
      Could also be moved channel frequencies or transponders? Premium channels are forever moving about. That coupled with picking up a faint signal from another sat would give those symptoms.
      Have you looked in "all" to see if there are ANY versions of the channels you want working? As you will know each channel is repeated a million times. :sly:
      • poyzy
        • Aug 2013
        • 31
        Hi Thanks for the replies. I have changed the firmware and added a new channel list. will check the Sat list if channels are doubled. SLY Sparts 1 &2 done work 3 4 do.. Strange.
        same with Movies some work and some don't signal at 5to7%
        im thing the box is bricked. as other box works fine on the lnb
        any other suggestions.
        • Nutsandbolts
          • Oct 2011
          • 1168
          Hi If the second box is working fine then it means there is nothing wrong with dish alignment/LNB or cables. Double check you have same frequencies for the channels as the second box. You may need to retune the channels in again.
          Regards.
          • poyzy
            • Aug 2013
            • 31
            I have done a blind scan and still an issue, or shall I do something else. Thanks alot
            • Hadron
              • Nov 2012
              • 2102
              Is this the only box connected to your dish, or do you have any other boxes connected to the same dish?
              Sometimes a second box connected to the same LNB can cause problems.
              • poyzy
                • Aug 2013
                • 31
                i have another box upstairs and i have tried another mate box and works all ok. it must be the box i think,
                • colpac
                  • Aug 2012
                  • 49
                  Im having similar issues, i have a f3 and a f5, f3 is working perfect, f5 has lost a lot of channels with "no signal" have same firmware and channel lists on both boxes and have reinstalled them on the f5 copying them from the working f3. Is my f5 box goosed then? only had it a month so can get it exchanged if it is.
                  • poyzy
                    • Aug 2013
                    • 31
                    More than likely as I have tried different fixes and still the same stays at 5% signal on some pay channels sly Sparts one . Help
                    • Hadron
                      • Nov 2012
                      • 2102
                      If you have 2 boxes connected to the same LNB at the same time, then that can cause problems with some boxes showing "no signal" on some channels.
                      You can test this by turning off the working box & checking to see if the "no signal" channels return on the non-working box. If this is the case, then the box needs the "no signal fix" as discussed here:-
                      You can buy them on Ebay for ?6 -?7.
                      • poyzy
                        • Aug 2013
                        • 31
                        hi have A DIAOD and tried this and still get 5% signal strength on sly saprts 1&2 3&4 work fine, also have another box disconnected and works all ok on the same LNB.
                        • colpac
                          • Aug 2012
                          • 49
                          Just tried mine with the f3 switched off and all my channels are back so looks like the "no signal fix" will sort mine out
                          • deanlecky
                            • Aug 2012
                            • 48
                            I would think twice before opening the box' thus invalidating the warranty, unless its last option.
                            • Hadron
                              • Nov 2012
                              • 2102
                              There's no need to open the box. The diode fix is fitted externally between the LNB cable & LNB socket on the box.
                              If you search for "no signal fix" on Ebay, there are currently 3 sellers.
