2 dishes 1 box
  • scooby21169
    • Jun 2011
    • 20
    2 dishes 1 box
    Is it possible to put two Dishes onto 1 box with a switch to move to different frequencies. Or is a motorised dish a better option. Thanks in advance !!!
  • **OVERRIDE**
    • 199
    Is possible,motorised better tbh....what sats are you looking at?
    • scooby21169
      • Jun 2011
      • 20
      Looking at novasport or hotbird for epl footy m8
      • **OVERRIDE**
        • 199
        Novasport is on hotbird but only if you have a official card,if your just using the one satellite get yourself a twin LNB,which will feed two STB
        • scooby21169
          • Jun 2011
          • 20
          Hotbird
          I have a skyboxf5s and its 28.e and want to tune in hotbird is it possible with another sky dish set to the correct frequency ???
          • **OVERRIDE**
            • 199
            Yes mate,hotbird has a strong signal if your using a mini dish,but as mentioned nova ain't available without a card
            • badboy1965
              • 191
              if you,ve got a fixed dish and sly lnb then you can only pick that satellite up 28 east,unless you move it to 13 east manualy and it wont pick all the channels up because sly lnb,s only pick up certain frequencys (not universal) get yourself a motor and bigger dish and the worlds your oyster
              • scooby21169
                • Jun 2011
                • 20
                can i plug an al jazeera hot bird card into my skybox f5s ???
                • **OVERRIDE**
                  • 199
                  Yes has a multi cas reader....
                  • scooby21169
                    • Jun 2011
                    • 20
                    kewl m8 thanks !!!!
                      Just for the Record $ly Single/quads are Universal LNBs.
                      For 13? east and 28.2? east then a minimum of around 80cm dish will be required to account for heavy rain fade margin, Have 13? east as the primary with 28.2? east as the offset and a 2/1 diseqc switch and you will have no trouble.
                      Unless you want to put up a separate dish for 13? east then i would still suggest a min of around 60cm just to be on the safe side
                      • P&D
                        • 2686
                        Sorry to highjack the thread but its on the same lines as the OP
                        Is it possible to run 1 80cm dish with 2 LNB's mounted on the same dish for 2 box's 1 upstairs 1 downstairs......
                        If i have got it correct ...
                        1 feed from each LNB to a diseqc 2x1 (lets say 13 east & 28.2 east )for the box upstairs and the same setup for the box down stairs
                        my question is can the box down stairs watch 28.2...while the box upstairs watches 13 east at the same time ??
                        many thx
                          your going to need twin lnb outputs and 2 switches for the last part of your question, if you only use 1 receiver at a time and one of them has an LNB loopthrough then you could use singles with 1 switch and then loop form either upstairs or downstairs to the other receiver or vice versa.
                          Obviously one receiver would have to be switched off while using the other, but to be honest for the price of twin LNB's and 2 switches its worth doing it that way so you could watch either sat in either room.
                          My original setup in one of the threads with Photo's shows mine with Smart Titanium Quad rockets X4 on 13?,19.2?,23.5?,28.2? east feeding four different receivers around the house
                          • scooby21169
                            • Jun 2011
                            • 20
                            No what i am saying is 1 dish 2 lnb ( 0ne at 28.2e and the other 13.0e) One receiver and a switch to change between lnb is this possible. or can i just change the lnb to accommodate the whole job.
                              My last post was answering P&D
                              Yes you can use 1 dish preferably an 80cm with the prime focus set at 13? east and the offset pointed at 28.2? east both going into a 2/1 diseqc switch with one cable going to your receiver
