A how to guide on how to fix a corrupt firmware image on the OpenBox and Skyboxs Even if the box seems dead (many thx to Darvash)
Box does not respond or theres on display On it
If your box does not boot or there is no display lights or stuck in load mode there is a good chance the current firmware on the box is corrupt.
You will need to use a null modem cable.. 1.8m Null Modem Cable - Lead RS232 DB9 9 pin FEMALE TO FEMALE | eBay, connect a Serial RS232 Null Modem Cable to the box and follow the instructions.
Hopefully it will bring your box back to life.
instructions
Download the files below
Unzip these files to your desktop & you will have 2 folders called
1 erom_upgrade_8Mflash.rar
2 Upgrade_PVR800_HD_Tool.rar
then unzip the firmware this is for the boxes listed is you have the open box or F5s box plz see SkyBox | SkyBox for your firmware
3 SKYBOX_F5_F3_M3_3601HD_CMT_1301230F1C.rar
Or use your own image if you have backed your box up before the crash.....
1. Connect your PC to the box using a null modem serial cable.
2. unplug the power source
3. Run EromUpgrade.exe or upgrade PVR800 then check the com port setting is correct
4. Select the latest firmware from above or the one you have downloaded..
5. Select "next" (also tick boot loader) then plug the power supply in the box
and follow the instructions to load and flash & burn the firmware.
6. if you use Erom upgrade & its sits there saying STB error then use Upgrade PVR800 Ie if one does not work us the other
7. Don't switch the power off or disconnect while the download & flash is taking place.
This is a video to show you how to load the firmware & flash the box..(thx to Terryuk22)...Openbox Bad Flash Recovery - YouTube
instructions
