Channel frustration!
  • mickerick
    • 45
    #16
    I`ll check it out....many thanks P&D, I appreciate your help!!!!
    • mickerick
      • 45
      #17
      Comes up file mismatch P&D?
      • P&D
        • May 2010
        • 2686
        #18
        if thats the case it sounds like you have a clone...if your getting file mismatch.....
        can you confirm its defo an F3 box
        Thry this one
        Skybox F3 & F5 Firmware Latest Firmware & Channel List Skybox F3 & F5 11.10.13 Date Added: 11-10-2013 12:03:19
        https://www.bradforddealer.com/download/
        Never used it myself tho
        • intel
          • Apr 2010
          • 128
          #19
          Definitely a clone box (had the same mismatch error a while back on a m8s box)
          Try this link
          http://www.yojiatech.com/a/Support/Download/Skybox_F3/
          • mickerick
            • 45
            #20
            Yep, just tried all of them...still file mismatch!!!
            • bigade1
              • Oct 2013
              • 340
              #21
              Here's another download site for clone boxes. If you scroll down it lists 2 lots of firmware for your box but according to this site you already have the latest version.
              www.hddvbsw.com
              • mickerick
                • 45
                #22
                Tried that one BA!....no joy!!
                • mickerick
                  • 45
                  #23
                  So if it won`t take either clone FW or proper FW, what can I do, or whats the problem, anyone?!
                  • P&D
                    • May 2010
                    • 2686
                    #24
                    After a few days frustration, my F3`s set up, but, still can`t get any HD Sly Movies, Boxnation etc,...I`ve updated with AJ`s list, checked all the TP`s of the missing channels, and still nothing......am I missing summat obvious? I`m pretty well a newbie to it all!!
                    What are you getting on the channels ???
                    No signal ?? Could be the dish moved
                    Scrambled ??? Thepartwecannottalkabout
                    or saying nothing ????
                    • intel
                      • Apr 2010
                      • 128
                      #25
                      I cant see that you need to change the FW as it was working before and you get 70% of the channels? I would
                      check the signal level on the channels that you cant get and report back..................if the channel is there
                      and the signal level is ok, but you get the $ sign, then you need to look further
                      from the box and and does it still say that the box is online? (things we can't talk about)
                      • mickerick
                        • 45
                        #26
                        Still on line, and its "No Signal" that I get, and "invalid channel" as well!
                        • P&D
                          • May 2010
                          • 2686
                          #27
                          sounds like the dish has moved....do you have the F3 running along side an official box ???
                          • mickerick
                            • 45
                            #28
                            No, its an oldish dish, not been used for a good while!!
                            • DW190
                              • May 2012
                              • 1263
                              #29
                              Have you any friends with a dish that you could try it on?
                              Sounds like it could be the lnb on its way out.
                              • mickerick
                                • 45
                                #30
                                Yeah, a mate of mine has the same set up, I`ll try it on his....cheers!
