Openbox S10 reboots on HD channels
that was the oldest s9 firmware that will boot on the s10,it was the transition period from solomend to s9 to s10Hi DW190, tried your image dump tonight on the box and it still reboots on every HD channel any ideas??
Everyone I've put my old firmware on, it boots up skybox and the version is CHDS2-11-03-25:00EBCM, this only has 8 favourites but all HD channels work fine?? I'm going to try the editor on the firmware and see if that works, anyone have any ideas why the box would reboot on HD channels? Must be firmware though??
Sent from my iPad using Tapatalk
Firmware prior to that will boot to -- on the s10,which is a hardware detection fault.Comment
Check how old is your sky dish lnb, you need digital to run hd channels!!!!!!!!!!Hi DW190, tried your image dump tonight on the box and it still reboots on every HD channel any ideas??
Sent from my iPad using TapatalkTools owned: Hammer, Chisel, Crowbar, Punch, Chainsaw, Cutter and Brain!!!
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
