openbox s11 help
  • dercio
    • Mar 2010
    • 78
    openbox s11 help
    i have openbox s11 was working fine but now just says boot on the front screen can some one tell me what firmware i need and the upgrade tool required to bring box back to working
    It is always wise to look ahead, but difficult to look further than you can see.
  • P&D
    • 2686
    Have a look here Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
    • dercio
      • Mar 2010
      • 78
      iv tried with thihs guide when using stb erom upgrade get message saying openbox initialize stb sdram is fail
      • P&D
        • 2686
        What's the name software are you using ???
        • dercio
          • Mar 2010
          • 78
          not quite sure its one i took from a google search : C2DS2_CMT_120620044F.abs
          please let me know if that right or wrong and if you know what i should use please tell me
          • P&D
            • 2686
            Sorry what upgrade tool are you using.....not firmware
            see below
            • dercio
              • Mar 2010
              • 78
              see below
              yes tried both of them still saying same message
              • P&D
                • 2686
                are you trying to upgrade by com or usb ???? also is it the correct cable
                must be one of them ???
                • dercio
                  • Mar 2010
                  • 78
                  upgrade via com box wont turn on just says boot on the front so cant do it via usb the cable seems to be ok cause its saying synchronizing with stb ... done then on bottom says
                  initialized stb sdram is failed
                  • P&D
                    • 2686
                    no mate are you using this cable usb USB to RS232 Serial Download Lead | PAT Tester Download Lead
                    or com port cable...https://www.google.co.uk/search?q=rs...2F%3B500%3B593
                    are you ticking ticked bootloader
                    • dercio
                      • Mar 2010
                      • 78
                      im usin 9 pin female to female normal null cable for data transfer at least when bought it online it mention data transfer
                      • P&D
                        • 2686
                        Might be the wrong cable there are 2 kinds......
                        where about,s are you ......if in the UK what postcode i'm in the WA9 area i could sort it for you in 20 mins
                        correct cable is....
                        http://www.ebay.co.uk/itm/Null-Modem...item19e5bef5e7
                        or
                        http://www.ebay.co.uk/itm/Manhattan-...item45edbedb4d
                        they are the correct one's & are both the same cable
                        • dercio
                          • Mar 2010
                          • 78
                          Im in london TW area think i will go maplins later on and see if they have another 1 i can buy ...
                          By the way i also have usb to cable wire but dont no how to use it on windows 8.1 heard i need to get driver before it works
                          • P&D
                            • 2686
                            I always use an XP comp & never had a problem doing them
                            sorry mate your 400 mile away ...so no nipping round to fix it & have a beer .....
                            good luck...make sure you get the correct cable
                            the 2 links above are the correct cable....Maplins will charge you ?20 robbing B....... well you know what i mean
                            Regards Phil
                            • dercio
                              • Mar 2010
                              • 78
                              Lol yeah i no i checked prices and its expensive but dont think i can go few days without tv so might have 2 go maplins just to save me from Bordem with tv anyways thanks for help
                              Cheers
