Problem Skybox M3,pleaseeeee help!
  • SMART057
    • Sep 2009
    • 13
    Hi, I encounter problems with "China" SKYBOX M3, let me explain: I can not connect to the internet, either by ethernet cable or by wifi, wifi although I find my bbox (90% signal) but after a while he told me that the time is exceeded and of course no connection wifi.Je do not know what kind of demo with my Dreambox I have no probleme.Si I look on my dashboard router has the address 192.168.1.254, in the scheme of my network I see nothing in ethernet, whereas if I connect the Dreambox it is. in network setting / ethernet / difficulty I put the DHCP "on" or "off" but nothing happens, can someone help me configure it. thank you
    Edit:I just tested with my Iphone shared connection, and it works! I connect to the wifi Iphone and chains opens! why my router does not connect this?
  • P&D
    • May 2010
    • 2686
    I think you should ask the question again...this time so we can understand the problem ???
    • Hadron
      • Nov 2012
      • 2102
      First of all, forget about trying to use wifi. It will only introduce more variables to your problem.
      When you connect by ethernet (network) cable, do you see the green light (& occasional orange light) on the ethernet port on the M3? Does your router show a green or orange light to show that it's connected to the box?
      What router do you have?
      Not sure if the M3 firmware is similar to F3, but when switching back to Ethernet (after using wifi) in the Network Settings menu, click on "Active" first.
      Does YouTube & You P0rn work?
      • sexysam
        • Oct 2008
        • 209
        Make sure in your M3 box you have DHCP enabled,otherwise it will not work, even though you have plugged in your Ethernet cable in back of box
        • SMART057
          • Sep 2009
          • 13
          Hello everyone and thank you for participating! Yes DHCP is "on", the green lights on the ethernet cable and router side skybox are green! youtube and you**** does not work, he told me that there is no server.
