Few questions?
  • boredasusual
    • Jan 2014
    • 21
    Few questions?
    1. How exactly do I upgrade to the latest firmware of F5s?
    2. Which is the best for channel layout AJ's list or Satts list? Also how exactly do I put either channel list on the box?
    3. When I click on the EPG it crashes the box altogether and I have to restart the box, what exactly causes this problem?
    4. Where do I get the newest EPG for seven days from?
    5. Would I need to back up everything if im going up update firmware or put new software on it? Would the USB have to be formatted to FAT 32 or can it still work on NTSC?
  • SpiKed
    • Feb 2013
    • 55
    Download the .rar file..
    Unzip file to recieve .abs file
    Put .abs file onto a USB stick
    Put USB stick into Skybox f5s
    Press Menu on the remote.
    Press Down (The menu is called "Tools")
    Press OK
    Go down to upgrade files by USB, Press OK
    Upgrade mode should already be set to "image file .abs" So go down to Start and press OK.
    Shh beat me to it, that will teach me not to refresh first
    2. Personal preference, although I think most prefer AJ's list(?)
    Same as above although,
    Delete old channel list first
    When on upgrade files by usb press right on the "upgrade mode" to set it to misc files
    then select tp.prog then press yellow
    There is threads in this forum with red text, they can help you if my steps are unclear
    3.You need to update your firmware
    4. Comes with latest f5s firmware
    5. Thethingthatcantbetalked about is backed up everything else I think you will have to back up yourself, people say it needs to be FAT32 but I don't think thats always the case
    3x Skybox F5S 1x VU+ Duo
    • boredasusual
      • Jan 2014
      • 21
      But where do I get latest firmware from?
      Also isnt it wise to backup the files on the box everytime I try to update or put things on? What files do I need to back up? How do I delete old channel list?
      • bobhope1
        • Nov 2010
        • 85
        SkyBox | SkyBox
        • genam
          • Apr 2013
          • 176
          4...doesn't come with the firmware update...access to it does...you still need to let the box 'update' the EPG itself.
          All the instructions are on Skybox website above
          • boredasusual
            • Jan 2014
            • 21
            Is there any simple way of backing up the files from the box before upgrading? Im confused what to do.
            • intel
              • Apr 2010
              • 128
              Yes...just go to >Tools, then Dump By USB and then select what you want to save....there is also a good tut by Shady in the link below.
              http://www.digital-kaos.co.uk/forums/f184/openbox-setup-guide-257009/
