Libertview (Skybox) F5s
Hi ive got all those perfect still not working. Im beginning to believe it must be a faulty tuner like the chap said above. Thankyou though, everyone, i really appreciate itComment
If you have same issue at friends house then is there any chance you can borrow their box (whether $ky or not) to double check that your setup is fine to receive channels.
If your friends box works fine at yours along with fact that your box doesn't work at his when his box does, means its likely a faulty box (maybe tuner).Comment
Hi all can anyone tell me how to get the network settings on this boxLast edited by spanishlion; 22 February, 2014, 01:36.Comment
Are you sure you have set it up to the right satellite. mine was setup to turksat. if not press menu and go to installation then go to satellite list. Find 28.2 and press ok then exit. Go to single satellite search and press ok on search if this Is the problem then voilaComment
