Libertview (Skybox) F5s
  • teamaker2014
    • Jan 2014
    • 9
    #16
    Originally posted by skybot1
    put a meter on the cable one at a time see if you get a lock on the satellite sounds like the dish has moved
    i dont suppose you can recommend a metre to use can you? Would that be the probem if im getting exactly the same at my mates house and we know his dish is fine as his sky works perfectly
    • teamaker2014
      • Jan 2014
      • 9
      #17
      Originally posted by bigade1
      Default settings should be:
      LNB setting = On
      Installation Antenna = Local Longitude 000.00E
      Local Latitude 00.00N
      LNB Power On
      Antenna Set Up = Satellite Sky UK 28A
      LNB Freq Universal 9750-10600
      DisEQC1.0 Disable
      DisEQC1.1 Disable
      Motor Type Off
      Hi ive got all those perfect still not working. Im beginning to believe it must be a faulty tuner like the chap said above. Thankyou though, everyone, i really appreciate it
      • bbb_uk
        • 429
        #18
        If you have same issue at friends house then is there any chance you can borrow their box (whether $ky or not) to double check that your setup is fine to receive channels.
        If your friends box works fine at yours along with fact that your box doesn't work at his when his box does, means its likely a faulty box (maybe tuner).
        • genam
          • Apr 2013
          • 176
          #19
          bbb_uk is right....just borrow a box of any type and prove your dish and cables are 100%
          • Adam7862
            • Apr 2012
            • 42
            #20
            I had the same problem with my openbox s11, the snr would just keep going up and down. The problem was with the box as ive now got a new box which works fines
            • spanishlion
              • Sep 2012
              • 7
              #21
              Hi all can anyone tell me how to get the network settings on this box
                Originally posted by spanishlion
                Hi all can anyone tell me how to get the network settings on this box, or how to put the sealion in
                when I go o upgrade by usb it doesn't allow me to upgrade a sealion file
                • spanishlion
                  • Sep 2012
                  • 7
                  #23
                  Are you sure you have set it up to the right satellite. mine was setup to turksat. if not press menu and go to installation then go to satellite list. Find 28.2 and press ok then exit. Go to single satellite search and press ok on search if this Is the problem then voila
