Clone check is hard these days, because the cloners are very good, its just the components inside the box that maybe different. Externally it would be very similar. The cardboard box the F5S came in, shoudl in theory have that QR code etc. Im just going by the SKYBOX website to be fair.
I would always recommend using the correct firmware, mainly because the flash partition and or kernal (drivers) for a particular box is only in a correct firmware. By using a firmware for another box could alter the memory partion. which is why I suspect your box boots up and then changing channels causing a freeze.
Just a thought if say you booted you booted your box, without even a LNB feed. does it crash then??? if it does not then can you upgrade the firmware (take the lastest f5s firmware)..
