Skybox/libertview box loading channels really slow... Please help!
  • rejaul
    • Feb 2014
    • 28
    Hi, can someone help me please, my libertview box/skybox is quite slow at loading channels, whilst pressing up and down on the remote... Never had this issue until loading aj new channels... Is that normal? Iv done factory reset and software firmware reset and uploaded aj new channels.
  • boobishabang
    • Nov 2011
    • 43
    Did you delete your old list of channels and reboot the box before updating the latest list?
    • rejaul
      • Feb 2014
      • 28
      Yes, went to channel list and deleted all channels then uploaded new aj list
      • boobishabang
        • Nov 2011
        • 43
        Have you tested going back to the old list or using the skytv list to see if the problem is defo down to the new AJ list?
        • rejaul
          • Feb 2014
          • 28
          Nope havnt tried it. Will try thanks
          • Slywalker
            • Aug 2013
            • 12
            As so many other people are using AJ's list it seems unlikely to be that (I'm using it without this issue) are you using the 7 day xml epg or the sat delivered? if it's the XML try changing to sat and see if the zapping is quicker, if so, look to your external storage device, maybe try deleting the epg from it and re-downloading.
            • rejaul
              • Feb 2014
              • 28
              im only using xml epg sat settings, and still the same problem... im not using any external usb or hd... only wifi antenna.
              • bbb_uk
                • 429
                Try this:-
                Backup channel list and other things you need.
                Remove wifi antenna
                Delete channel list
                Restore to defaults
                Reboot
                Load up latest firmware (for F3S and F5S it's dated 22/01/14)
                Reboot (which will be automatic after a firmware update)
                Restore to defaults
                Load AJ's latest channel list
                Reboot
                Now see if that helps before changing settings or adding EPG/PICONs or your wifi antenna.
                • bbb_uk
                  • 429
                  Did the above work for you rejaul?
                  • rejaul
                    • Feb 2014
                    • 28
                    It did not work sorry.
                    • bbb_uk
                      • 429
                      If you believe this is related to AJs latest list (but I and others have no issues like this) then:-
                      Delete ALL channels (this is important)
                      Reboot
                      Go back to AJ's last channel list here (dated 11/01/14).
                      Reboot
                      Try that and let us know.
                      • rejaul
                        • Feb 2014
                        • 28
                        It's still slow... Plus iv had issues such as my libertview box crashes if I change channels a lot. Does anyone else have this issue?
                        • bbb_uk
                          • 429
                          What box do you have? Also, in what way is box crashing?
