Hi, can someone help me please, my libertview box/skybox is quite slow at loading channels, whilst pressing up and down on the remote... Never had this issue until loading aj new channels... Is that normal? Iv done factory reset and software firmware reset and uploaded aj new channels.
Skybox/libertview box loading channels really slow... Please help!
Did you delete your old list of channels and reboot the box before updating the latest list?Hi, can someone help me please, my libertview box/skybox is quite slow at loading channels, whilst pressing up and down on the remote... Never had this issue until loading aj new channels... Is that normal? Iv done factory reset and software firmware reset and uploaded aj new channels. -
As so many other people are using AJ's list it seems unlikely to be that (I'm using it without this issue) are you using the 7 day xml epg or the sat delivered? if it's the XML try changing to sat and see if the zapping is quicker, if so, look to your external storage device, maybe try deleting the epg from it and re-downloading.Comment
Try this:-
Backup channel list and other things you need.
Remove wifi antenna
Delete channel list
Restore to defaults
Reboot
Load up latest firmware (for F3S and F5S it's dated 22/01/14)
Reboot (which will be automatic after a firmware update)
Restore to defaults
Load AJ's latest channel list
Reboot
Now see if that helps before changing settings or adding EPG/PICONs or your wifi antenna.Comment
